Question about Compaq Presario Notebook
Compaq Presario c300 power light blinks..
I have a Compaq Presario c300. When I plug in the AC Adapter... it runs fine for a good while, but then just cuts off. I try to power it back on, but the lightning bolt light on the front blinks 3 times... that's it.
When I leave it alone for a good while... sometimes I'm able to cut it back on again....
  • dannywestjon Nov 28, 2008
    Thanks for the quick reply... this laptop is at least 3 years old. There's another adapter I used... and it doesn't respond when I hit the power button at all, but the lightning light flickers on and back off again when I use it.
    Since it consistently produces one error (3 lightning flashes when the power button is pressed) with one adapter, and another error (just a flicker on the lightning light when plugged in, then nothing on pressing power button). Both adapters are the same, and are made for the Presario c300.
    Being used to printers flashing lights and giving codes by the sequence of light-flashes and such... I was thinking maybe the Presario was doing the same thing. I was curious what the "blink, blink, blink" meant. I just wanted to be sure I was "barking up the right tree" by getting another power adapter...
  • 3 Answers
Take off cmos battery and sort battery pins this will solve yours problem try it thanks
Posted on Feb 14, 2011
  • david michael walsh Feb 26, 2013
    absolutly brilliant,i have spent hours trying to get my laptop to boot, thanks .
    Problem Solver:
  • 12 Answers
It sounds to me like there's a short in the AC adapters causing it to have enough power to charge the unit when it's not pulling power, but once it starts pulling power, it basically becomes overwhelmed and can't do both power and charge. There's also the chance that the DC jack [which the AC adapter plugs into] is bad. However I'd suggest checking the adapter first because it's simple to obtain a new one and if it doesn't work, you can most likely just return it and say it doesn't work as opposed to a dc jack being repaired which would have to be done by a professional with the skills to handle it [of course unless it's under warrenty, less than a year old, but judging by the model I'd say it's probably not]
Posted on Nov 27, 2008
    Scholar:
  • 156 Answers
That may not be a problem with the AC adapter. After connecting to the wall socket and switch on and check the output voltage at the DC out. if that is OK, the problem is most likely with the motherboard.Either with the power jack or there is mosfets & capacitors in the power up & charging circuit as well as other small components that may fail overtime or by hard use.. A good motherboard chiplevel technician can easily fix it for you. Hope this may help.
Posted on Dec 01, 2012
4 Suggested Answers
frenzy19
  • 258 Answers
SOURCE: Flashing lightning bolt on Compaq C300
i think the battery is depleted so the power supply can no longer charge the battery
Posted on Dec 09, 2008
kunaps
  • 6 Answers
SOURCE: Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
Posted on May 28, 2009
  • 3 Answers
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Posted on Sep 28, 2009
Why my pc presario x1000 power and lamp lights blink and the batteries can not be on my pc
I fix these laptops as a side business and sell refurbished ones on ebay...I've seen the problem you describe but I'd need to know more about how fast they are blinking, etc. When all the lights flash about 2-3 times per second, I've found it to be a motherboard issue normally caused by a faulty power jack. That can be fixed but it means disassembling the complete laptop down to the motherboard and either re-soldering or replacing the jack. If you have access to a charged battery, disconnect the AC adapter and try to get it to boot cleanly from the battery. This will tell you if the problem is at the jack or someplace else. Post your results and we'll go from here.
Jun 09, 2012 | Compaq Presario X1000 Notebook
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq presario c300 wont turn on at all
Looks like a bad motherboard ,have you tried another power adapter the one that connects to the wall socket.
The motherboard could cost over $100 ,chepaer on Ebay or you could take it to a Compaq/HP service center and ask for a quote on the repair.
May 13, 2009 | HP Compaq Motherboard
Laptop wont power up on batter but will on adapter
It sounds like you dc jack is not functioning if you are could with solder and disassemble you can do that yourself . Otherwise you can get it repaired for around 75-100 dollars
Feb 13, 2009 | HP Compaq Presario v3000z Notebook
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Compaq presario does not turn on
Your battery is dead. You need to get a new power adapter. The battery isn't charging. The AC adapter went south. If the laptop is under warranty, you can get one from Compaq. Or, what I would do is shop on the internet and order one. Whats the numbers on the ac adapter? I'll help you find one.
Jun 30, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
2,539 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
