Instructions/Steps to recognize memory installation on my Inspiron 1200?
    Scholar:
  • 160 Answers
Try checking the memory at www.crucial.com it will scan and tell you what and how much you memory you have. if the memory you installed was done properly and there are no error reports in the event log, it should be fine after a re-start.
Posted on Nov 27, 2008
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
How do I turn on the external vga port on the back of my Dell inspiron 1200 laptop? If I hook a monitor to it, is there a way to turn it on?
If you hook a2nd monitor to the port do it with power off and restart, the system will find it and try to install the driver , but you can find the latest driver , save it and follow the steps above.
Oct 05, 2010 | Dell Inspiron 1200 Notebook
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Memory upgrade for Inspiron 1200
your new ram is either bad, or incorrect, speed. Try to copy the working ram for the correct type
Feb 15, 2009 | Dell Inspiron 1200 Notebook
SYSTEM DOESN'T RECOGNIZE NEW MEMORY MODULE
Memory modules must be the correct type and speed, and be within the specifications for the laptop. Just because it fits in the slot doesn't mean it will work.
The Dell inspiron B130 has 2 slots. Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. if you tried to insert a 2GB module, it will not work.
If the module is within these parameters, remove and re-seat the memory, and try swapping the modules from one slot to the other. It may be a bad slot.
Dec 28, 2008 | Dell Inspiron B130 Notebook
Dell Inspirion not recognizing both memory slots
MAKE SURE BOTH SLOTS ARE ENABLED. ALSO MAKE SURE THERE IS NO CONFLICT FOR THEM IN DEVICE MANAGER
Dec 10, 2008 | Dell Inspiron 6000 Notebook
Verify memory upgrade in a Inspiron 1200
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Dell Inspiron 1200 Notebook
Dell Inspiron 1200 no POST
There are two memory slots on this model, but there is no "Onboard" memory. Without the memory that you removed, your laptop will not post. It sounds like a dead motherboard issue to me, especially since you have pretty much torn it down to barebones. Rarely, this can also be caused by the processor but it is less likely. Unfortunately, since you cannot keep it running, there isn't much chance of diagnostics. I hope this helped.
Apr 20, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Dell Inspiron 1200 laptop
Sounds like you have a bad Stick of ram.If you have 2 sticks remove one then try to load the operating system.If that doesnt work replace it with the other one and try to boot.If you are not sure what ram is leave a comment and I will explain.If neither work buy a new stick of ram and that should take care of your problem.Rate me if this works!GOOD LUCK!
Nov 17, 2007 | Dell Inspiron 1200 14.1 XGA LCD...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
