Question about Intermec CK30
Intermec CK30 Won't Display Desktop
I've got a CK30 that powers up and displays that it is refreshing the file system but, the desktop doesn't fully load. It is running Windows CE. I'd prefer to fix this myself if possible. Any help I can get would be greatly appreciated.
  • 61 Answers
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Posted on Apr 05, 2009
What Intermec is calling a desktop is just a splash screen saying "Intermec" and "CK30", not a true desktop. It's loss is an unimportant error.
Posted on Jul 17, 2010
Ck30 freezing up
you must have a network issue or the CK30 experienced a power surge, if you have others that work, then that unit could be defective and needs service.
Oct 18, 2013 | Intermec CK30 Handheld Computer
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
My computer screen keeps jumping or won't stay up
Your laptop screen refresh rate is low (Hertz). When your screen refresh rate is slow, it will flicker and stutter.
To fix this, right-click your desktop, and go to Personalize.
When you're there, go to "Display Settings" and go to "Advanced Settings", on the "Monitor" tab you'll see the screen refresh rate. Change it to the highest number you see.( min 65-70)
Although the change will shorten your laptop battery life, it will fix the problem. Just keep your charger on until it's fully charged, and it should be good.
Jul 22, 2012 | Computers & Internet
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Jul 31, 2011 | HP Pavilion a1110n (PX743AA) PC Desktop
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
2 of the slots don't hold battery in place to charge
Return it to the manufacturer for a refund, or a replacement.
Jul 29, 2009 | Intermec 4-Slot Battery Charger for CK30...
Intermec CK30 Error Opening Wedge Problem
I was getting the same error and resolved it by removing the battery and pressing the reset button. When you turn the scanner back on all the data will still be intact.
Apr 24, 2009 | Intermec CK30 Handheld Computer
Green light stuck on.
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Sep 12, 2008 | Intermec CK30
Intermec CK30 Logo
548 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
