Question about Amana ABC2037SS Air Conditioner
My Amana Prestige Ultra Central Heating Unit doesn't seem to be working, I would like to know if there is a hard reset switch or button on the unit?
  • 1 more comment
  • jwoodspv Nov 27, 2008
    When I switch from Auto to on the fan does not start, When I cycle past the set temp as if I were trying to manually start it, it clicks but not fan nor air or heat.
  • jwoodspv Nov 28, 2008
    Thank You!!! it worked the fuse was blown it was a 3 amp I replaced with a 5.
  • Ken Bledsoe May 11, 2010
    Can you turn the fan of from the thermostat by going from auto to on? Also is it a hot surface igniter or does it have a pilot light?
  • 306 Answers
Ok sounds like your transformer is not working. Now as long as no one has removed the doors to the furnace cabinet and they are in place just like the are suppose to be, because there is a door switch that turns off the power to the whole unit until the door is in place correctly. Find the circuit board and look to see it you have a fuse on the board it will look like a car fuse the spade type they are 5 amp fuses. If it is good find the transformer and replace it. If you feel comfortable around electricity there are two sides to the transformer line voltage which is 120 and the secondary side which is 24 volts. If you have a volt ohm meter ohm out the transformer each side line side and low voltage side. An open on either side will be noticed and then replace the transformer. I know this is alot of things to check but just elimanating everything it could be before condemming the transformer. Turn the main breaker off and replace.
Posted on Nov 27, 2008
  • Ken Bledsoe Nov 27, 2008
    One more thing if you can't find a fuse then the board doesn't have one.
  • Ken Bledsoe Nov 29, 2008
    When you changed the fuse look in your manual and make sure what the fuse size is. If you took out a 3 amp go back in with same size. It protects the board.
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Nov 05, 2012 | Siemens RWB29
I have the Amana Prestige Ultra. Installed about 6 years ago. I live in a nice climate so we only have to use it for a few hours during July/Aug/Sept - and in august all day for a few weeks. The...
Hello
There could be a few problems.First the compressor is heating up and causing it to pull high amps and triping the breaker.THis could be caused by low freon or low oil.
Possibly a restriction in the freon lines to and from the unit.These are some things a repairman should be looking for.
You can clean the outside unit,fins and coils with a degreaser and a water hose and see if this helps.
Jul 31, 2011 | Amana Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Mar 16, 2009 | Amana PTC153B50AM Split System Air...
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Compressor reset switch?
no, just unplug it for a few mins. then plug it back in. that is the universal reset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 01, 2007 | Heating & Cooling
Heating & Cooling Logo
715 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
