Question about Dryers
Kenmore gas dryer not heating up
I have a kenmore gas dryer, it turns on and even ignites, but after about one minute the flame turns off and therefore doesnt dry any clothes???????
  • inbtown Nov 28, 2008
    Thanks a lot oldfixer!! I took off the black coils, is there any way to check these coils to see if they work or not???
    Genius:
  • 1,028 Answers
Ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Posted on Nov 27, 2008
Dryer heats for 5 minutes then no heat, but keeps tumbling
Perhaps the flame sensor is not working. If it does not sense heat, it will shut off the gas. You might go online and search for a manual to help you troubleshoot, or go to:
http://www.repairclinic.com/
for troubleshooting help and parts. I hope this is of help to you.
Jan 16, 2014 | Dryers
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Kenmore dryer, saw igniter heats up, seconds later flame came out, started heating up then 4 to 5 minutes later flame and igniter sthut off,
sounds like bad gas coils the hold or assist, but i would change them both at the same time
they are the lilttle cylinders on top of the gas valve
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Dryers Logo
295 people viewed this question
Top Dryers Experts
Marvin
Marvin
