I have a 838gm gateway,Ive tried to install 4gb of ram ,when I install more than 2gb,it will not boot
  • c r
    c r May 11, 2010
    what os? did you check how much additional ram the pc could handle before adding it?
    are the ram modules the same type, speed, etc?
    Scholar:
  • 81 Answers
try to check your motherboard it is INTEL 915G if so, see this info below.
1.6 System Memory
The boards have four DIMM sockets and support the following memory features:
• 2.5 V (only) DDR SDRAM DIMMs with gold-plated contacts
• Unbuffered, single-sided or double-sided DIMMs with the following restriction:
Double-sided DIMMS with x16 organization are not supported.
• 4 GB maximum total system memory. Refer to Section 2.2.1 on page 55 for information on the
total amount of addressable memory.
• Minimum total system memory: 128 MB
• Non-ECC DIMMs
• Serial Presence Detect
• DDR 400 MHz and DDR 333 MHz SDRAM DIMMs
Table 6 lists the supported system bus frequency and memory speed combinations.
Table 6. Supported System Bus Frequency and Memory Speed Combinations
To use this type of DIMM… The processor's system bus frequency must be…
DDR 400 800 MHz
DDR 333 (Note) 800 or 533 MHz
Note: When using an 800 MHz system bus frequency processor, DDR 333 memory is clocked at 320 MHz. This minimizes
system latencies to optimize system throughput.
􀀒 NOTES
• Remove the PCI Express x16 video card before installing or upgrading memory to avoid
interference with the memory retention mechanism.
• To be fully compliant with all applicable DDR SDRAM memory specifications, the board
should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure.
This allows the BIOS to read the SPD data and program the chipset to accurately configure
memory settings for optimum performance. If non-SPD memory is installed, the BIOS will
attempt to correctly configure the memory settings, but performance and reliability may be
impacted or the DIMMs may not function under the determined frequency.
2.2 Memory Resources
2.2.1 Addressable Memory
The board utilizes 4 GB of addressable system memory. Typically the address space that is
allocated for PCI Conventional bus add-in cards, PCI Express configuration space, BIOS (firmware
hub), and chipset overhead resides above the top of DRAM (total system memory). On a system
that has 4 GB of system memory installed, it is not possible to use all of the installed memory due
to system address space being allocated for other system critical functions. These functions include
the following:
• BIOS/firmware hub (2 MB)
• Local APIC (19 MB)
• Digital Media Interface (40 MB)
• Front side bus interrupts (17 MB)
• PCI Express configuration space (256 MB)
MCH base address registers, internal graphics ranges, PCI Express ports (up to 512 MB)
• Memory-mapped I/O that is dynamically allocated for PCI Conventional and PCI Express addin
cards
The amount of installed memory that can be used will vary based on add-in cards and BIOS
settings. Figure 17 shows a schematic of the system memory map. All installed system memory
can be used when there is no overlap of system addresses.
click the link below for more info :
http://www.eserviceinfo.com/download.php?fileid=16744
Posted on Nov 27, 2008
  • Alver Clamonte
    Alver Clamonte Dec 02, 2008
    It's my privilege, that I can help in your problem.
    and if you have encountered another problem, feel free to post additional comments.
    thanks for the rating
    God Bless.
    President:
  • 2,992 Answers
Gateway's website says this motherboard will support 4GB of DDR333 or DDR400 memory. I would suggest testing each memory modules by plugging it into the board by itself, then rebooting. This way you can catch a bad DIMM that might be causing problems. If each one checks out then start adding one module at a time, rebooting after each one. If it still stops booting after you add a module, you probably have a bad system board, and only now that you are adding the extra memory are you finding that out. If that is the case, try contacting Gateway support. Maybe they would be kind enough to cover repair under warranty.
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
My pc keeps hanging when i install an additional ram which is 4gb my current ram is 2gb My specs is: Intel Core i3 530 2.93GHz 2GB RAM 2GB Palit GeForce GT 610 1TB HDD Windows 8 Pro 64-bit Asus...
what clock speed is $are 2gb Cards. You should use 2 2gb cards rather than 4 1GB cards. If you can boot up down load Belarc Advisor and run identify particulars. It's free.
Sep 03, 2013 | Gateway Dx4831-01e Intel Core I3-530 2.93...
Can i install 2 X 2gb ddr sdram on my Gateway GT5082
From what I gather you can use DDR PC3200, DDR (non-ECC) that equate up to 4gb of ram. So, as long as the RAM you are putting in is PC-3200 and no more than 2gb per stick, you should be good to go.
Apr 14, 2011 | Gateway GT5082 PC Desktop
Hp xw9300 workstation bios shows 4gb of installed ram but the system properties when the pc is booted up only show 2gb of ram. Whats the fix for this?
If you running a 32 bit version Operating system it does happen. since there's a limit for 32 bit operation though the mother board can handle 4gb.
other common cases: 1 of the sticks are bad. try to reseat the memory sticks to isolate which ram is not detected.thanks
Jan 14, 2011 | HP xw9300 Workstation PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
My computer does not work with two 2GB RAMs
I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
Jul 30, 2010 | Intel DG31PR Motherboard
More ram and vdeo card
it sounds as if your MoBo is seeing the video adapter as a source of ram. if that is the case, then installing memory in units of 1Gb will cause a stick to not be seen, therefore utilized. you may want to refer to you manual for memory limits and poosible comparibility issues. they are usually quite in depth. also, make sure that they are all the same make model and speed. these issues have wreaked havoc on the prettiest of pc's.
Nov 28, 2008 | Computers & Internet
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
I own a Toshiba Satellite M110...The problem I'm having is I can't get the laptop to run on anything higher than 2gb of ram...Yet the booklet and numerous tech and information sites say that it can run...
if i will suggest i think u can try a diff ram most times rams that r not compatible with each other may not run on a system. so to veriyfy that yr new 2gb ram pair is working try to install them one after the other that is, insert the first 2gb ram boot yr system if ok, shut down remove it n insert the other 2gb if it ok then they should work since it has been tested by the manufacturers n is written in the manual..
NB most times especially china products they may write anything on the body of yr machine but u will see a diff thing working so i dont know
guess u find help
May 27, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
215 people viewed this question
Alun Cox
David Payne
David Payne
