Question about Panasonic CT-27HL14 27" TV
Blinking light When I turn on TV, it goes on for one seciond, no picture comes on adn he power light starts blinking with no picture at all - looks like the TV is off. The sound (which is hooked through y home entertainment system) still works. I've only had the TV for 1 year and 3 months.
    Scholar:
  • 168 Answers
The symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Posted on Jan 16, 2007
SOURCE:
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
When TV is turned on, green power light comes on and picture starts to come on, after a couple of seconds the picture goes out along with the green power light and the red standby light comes on and blinks...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 01, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Everything looks great then the picture goes off, the green light blinks on and off but no picture comes back..intermittandt, but will occur every 10 to 15 mins or so, have to unplug the set and then...
You have the television on sleep mode. You'll have to disengage the sleep function! Most tv have this option so that you can go ahead and snooze for a while and the tv will turn itself off!
Dec 07, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic CT-27HL14 27" TV Logo
160 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
