Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Amana Refrigerator Top part is refrig,, not cooling, bottom part freeze, is is working fine ? Rear fan on unit is working fine. Light in refrig./freezer working fine.
    Sergeant:
    Champion:
  • 311 Answers
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Posted on Nov 28, 2008
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
My refrigerator and freezer working fine,but the door jam between freezer and frig gets very hot can anyone tell me why ?
Either the fan which cools the coils and compressor , behind the rear panel behind the refrig , is not working ( or something is caught in the fan blade ) , or , the coils under the refrig need cleaning badly .
Jun 19, 2010 | Whirlpool ED2FHGX Side by Side...
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
I have an amana ABB2224DEB. The freezer is working fine but the refrigerator has NO cooling whatsoever any suggestions?
open the freezer door, can you here a fan blowing??? if not that may be your problem, the evaporator fan not blowing cool airr up to refrig section,
Dec 06, 2008 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
308 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
