Question about Jenn-Air Kitchen Ranges
Gas oven not igniting, but broiler does with new igniter
  • jameskozack Nov 27, 2008
    i replaced the oven ignitor, the broil feature works, ignitor glows and starts gas., but for oven features, the display works correctly but ignitor will not glow
  • jameskozack Nov 29, 2008
    The solution got me thinking in the right area. All i could see was the top burner and ignitor. I began searching for the bake element, below the bottom plate. Now i realized that there are two ignitors. replaced and the oven works.
    Sergeant:
  • 291 Answers
Try to clean the bake burner bar to make sure nothing is obstructing the gas flow. A good old fashioned pipe cleaner does wonders.
also
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting. gas oven not igniting, but - flame.14x20.gif If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
click this link
http://www.appliance411.com/faq/gas_range_ignition_systems.shtml
Posted on Nov 27, 2008
    Scholar:
  • 174 Answers
You may want to try to clean the bake burner bar to make sure nothing is obstructing the gas flow. A good old fashioned pipe cleaner does wonders
  • Jenn-Air Master
  • 19,396 Answers
Usually this is caused by a faulty igniter, try to see if there is spark and flame on the ignitor.
  • Ginko
    Ginko Nov 27, 2008
    Sometimes this can also be because the safety valve that prevents accidental gas flow is defective, or the thermocouple that controls the valve is defective.
    Rarely this can also be caused by a faulty switch or control.
    The main suspect is always the igniter.
    Genius:
  • 1,847 Answers
The ignitor will be attached to the burner, open and examin for fault. Usually 2 quarter inch screws. Of course the ignitor has a harness that runs to the safety valve. You can either cut the wires and connect the new ignitor using ceramic wire nuts or you can follow the harness down. It's easier sometimes just to splice the wires and wire nut it, using the ceramic wire nuts.
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
The oven & the broiler don't work. There is
You will need to get a new igniter kit. If there is gas and no spark, then igniter is most likely faulty. You can go to repairclinic.com for parts and manual
Sep 09, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler and oven igniter the same?
you may not need a igniter. the problem could be with your control board which supplies power to both the broil igniter and the oven igniter. In my years of working on ovens i have not seen a oven that needed both igniters replaced.
Mar 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
117 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
