Question about Cuisinart DFP-11 Deluxe Food Processor
Won't turn on
I don't have the manual and have forgotten how to assemble and operate it.I don't know if it locked on properly.
  • Anonymous Mar 12, 2009
    My Cuisinart Deluxe 11-cup food processor won't turn on. It worked a few months ago. I am sure that all the parts are locked on, yet it won't turn on. I'm wondering if part of one of the plastic components broke, perhaps, and even though it seems locked, it isn't? Or could have something electrical just died?
  • 8,596 Answers
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
The manual is available on Cuisinart's website
Posted on Dec 15, 2008
We received one of these brand new (never been used) . Went to use it, and it won't turn on. It also won't shut off. Power light IS on. Assembled per the instruction manual, but it won't turn on.
You have told me the answers to the questions that I would first ask. There are interlocks that prevent the unit to operate unless the lid is on and so forth. if the light is on, then you have power. Depending on how comfortable you are with troubleshooting this, I would suggest looking at the interlock switches and seeing if there is an issue with them. This involves taking the case off and powering it up in this way to look at the switches.
Mar 06, 2017 | Food Processors
I don't have an instruction manual (wasn't in the box) and I don't know how to use the slicing/shredding blades or the additional smaller bowls.
A manual for the FP-14C series which the Cuisinart site indicates is applicable to your specific model is available online:
http://www.cuisinart.ca/pdf/ibs/en/FP-14DCC_en.pdf
See page 8 for assembly instructions. Beginning on page 20 is an included recipe section.
For future reference available Parts & Accessories are listed here:
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=328&item_id=281&cat_id=7
Aug 13, 2011 | Cuisinart FP14DC 14 Cups Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Will not cut on
In order for the processor to work, the bowl, lid AND pusher must all be in place - if one part is out of place, it will act dead. The proper assembly varies by model #. If you call Cuisinart at 1-800-726-0190, they are very good at getting you through the proper assembly.
Sep 04, 2009 | Cuisinart Food Processors
My food processor light is on but i need to press and hold the black button please help
Use a ball-point pen to depress the button - your finger simply will not do.
This is only to test the motor.
Once it makes the proper sound, you are ready to assemble the workbowl - once properly assembled, the workbowl, lid, and pusher itself will push the button for you. On the DLC-2011, the proper assembly is for the work bowl handle to be locked toward the front of the processor. If you are still having trouble or you have a model other than the DLC-2011, call Cuisinart at 1-800-726-0190 and they will help you with the assembly.
Aug 18, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
Unit assembled, lights are on (pulse, on) nothing happens
Jul 19, 2009 | KitchenAid KFP740 Food Processor
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Cuisinart DFP-11 Deluxe Food Processor Logo
564 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
