Question about Hitachi 46W500 46 in. TV/DVD Combo
DVD player My dvd sleeve is stuck partialy open after my 2yr old tried to pull on it while it was inserting a dvd. Now its frozen and wont eject or go all the way in. It's probably 2 inches out, I assume it must be off track or something. Tried to turn the power off and reset tv with no sucess. I was told that it may or may not be repairable but they want me to bring in the whole unit not easy with a 46in! Does anybody know if it can be fixed or if I order a new dvd sleeve at a cost of 300bucks will I be able to replace it myself without some technician charging me another 200 to put it in?
  • Jason Irvine Jan 15, 2007
    Mars Bars I owe you a huge thanks. Once I pulled the speaker cover off I was able to pull the sleeve out and took the top off the DVD player and found the dvd arm jammed, and was able to free it. Works like a charm! Without your advice I think I would have just let somebody else look at in in fear I would make things worse not even knowing where to start with the removal. I was figuring on having to take it out from the back of the TV, you saved me alot of dough thanks again.
Yes, the DVD sleeve is pretty accessible. All you need is a pretty standard phillips screwdriver. First, pull the speaker screen out from the bottom of the tv. Then unscrew the screws necessary to remove the sleeve. I haven't done it a while, but I believe there is one layer before you get to the sleeve. Before ordering a new DVD player, I recommend removing the sleeve and checking for problems yourself. If you're not too tech saavy, perhaps you could call a friend to help? I think maintenance would be a useless waste of money. Good luck, let me know.
Posted on Jan 14, 2007
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Need to get stuck DVD out. How do I remove the DVD player?
Before removing the DVD player...1st try inserting an old DVD disc under the stuck one, and press eject...this usually works...hope this helps.
Sep 24, 2015 | 2006 Chrysler Town & Country
It will not let me insert a disc and when I press the eject button, it sounds like it is going to eject a disc and then it makes a weird noise for 5 seconds. Then, it will say CLOSE for a bit. I got one...
It sounds like you have 2 disks stuck in there. TV repair shop, or try shaking the dvd player lightly while dvd is trying to open. You may need to help open the door, but too much effort could cause harm.
Jul 08, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Dvd tray wont open
Hello
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
6. You might need to see a technician.
GOODLUCK
Jan 27, 2011 | Amphion Mediaworks S99 DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Nov 23, 2010 | Denon DVM-1805 DVD Player
LG DP581B please i need codes to make my portable DVD player multi region for my 2yr old daughter tried a few that already posted for other models but didnt work!
This works 100%.
Download http://www.sendspace.com/file/ryt1gz
-open and burn the ISO to a CD-RW
-turn on dvd player with no disc in
-insert the CD in dvd player
-Wait until the on-screen region menu appears
-press "0" (zero) on dvd remote
-press pause on dvd remote
the dvd player should go back to normal operation and be region free.
Oct 20, 2010 | LG Televison & Video
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
Hitachi 46W500 46 in. TV/DVD Combo Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
