Question about Zanussi FS1455W Front Load Washer
Door seal replacement
Got a new door seal and took off the old one. how on earth does it fit back on?
  • Alexander Shewan Jan 30, 2007
    I am unable to work out how to get the new seal back on to the machine. I am also unable to locate any info on the net that will guide me through this painful process. Looks like I'll need to get 'the man' out to fix it for me.
    Problem Solver:
  • 13 Answers
Plenty of washing up liquid and soak it in hot water for 2 mins. use both hands and snap on the gasket. pull the spring to make it slightly biger . unplug machine place screw driver through the hole in the lock to keep spring inplace and feed spring around. then place the front of the seal back on and push the clip back and tighten it with pliar hands. appliance doctor
Posted on Feb 02, 2007
Can gasket for CR09FFW be replaced?
if you are referring to the door seal ( sometimes called a gasket) yes it can be replaced by a new genuine item or in some areas there is a private operation that goes around making door seals to fit and are fitted as part of the price
look in the yellow pages (business directory ) for refrigerator repairs or refrigerator door seals
Note here - although you may contemplate doing the job your self , some old seals are glued in and need knowledge as how to remove it , and the door will some times go out of shape when the door shelves panel is removed so it is best to get in a professional to do the job
Nov 11, 2015 | Crosley Refrigerators
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Need to replace the door gasket. Can this be done with the door on?
    Door on is the preferred method for me. Once you take it off and place it on the floor you can break the handle. (must remove the handle if you remove the door or place it on blocks of wood. (IF you remove it)
    It is a matter of loosening the screws removing the old door seal and fitting the new door seal in place.
    (Tighten the seal mounting / hold down screws when your done fitting the new seal.)
    Thanks for using FixYa!
    Kelly
    Feb 19, 2010 | Washing Machines
    Rubber door seal replacement on my Front Load Washer
    OPEN THE DOOR
    THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
    TAKE OFF THE CLAMP
    FOLD THE SEAL BACK INTO THE DRUM
    YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
    SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
    FIT A NEW ONE IN REVERSE ORDER.
    HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
    HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
    Jul 06, 2009 | Whirlpool Washing Machines
    How do i change the door seal?
    You'll have to find the screws that hold the door skins together. Take them out, replace the seal & reverse the order.
    Feb 13, 2009 | Select Brands Washing Machines
    How to replace door seal of Hotpoint WF860 washing machine
    Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
    Good luck................
    Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
    How do I replace the door seal on a Neff under the counter refrigerstor?
    Some door seal gaskets just wedge into place and are easily replaced. Replacing the gasket is simply the reverse of removing the old one. You peal out the old gasket and fit in the new and press it into the slot.
    Jul 11, 2008 | Neff Refrigerators
    Zanussi FS1455W Front Load Washer Logo
    154 people viewed this question
    Top Zanussi Washing Machines Experts
    shaun taylor
    Marvin
    Marvin
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
