Question about GE GSL25JFPBS Side by Side Refrigerator
Not cooling properly
Just replaced the evap fan and still does not work.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsjgs
Posted on Sep 29, 2010
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
Refrigerator not getting cold and the freezer will only 30 degrees we just moved into the house and the refrigerator was left here
Make sure the fan inside the freezer is running. A lot of times if a unit is left with no power or off the evap fan can stick not letting it turn to circulate the air for proper cooling. Most of the time they can be unstuck without having to replace the evap motor.
May 31, 2010 | Maytag MSD2756G Side by Side Refrigerator
Model 106 56569400 - Freeze side appears to be Ok. Refrig side not cooling to set temp 37. Current temp is 55-60. Door appears to seal properly.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Jan 27, 2010 | Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling due to non frost system not working properly, its fan stop from frozen ice.
you probley need a heater element on the evap.. this causes ice build up on evap and will not cool......
Aug 12, 2009 | Refrigerators
Changed a/c evaperator and compressor, runs about 48 degrees temp goes up when you slow down cant find screen in high side line.
Is your cooling fan working properly? Usually when going down the road, it will cool better due to more airflow over the condensor. If your cooling fans are not working properly, this will add to the effect. Is it going to like 60-65 degrees at idle, or like 55 degrees? 60-65 is cooling fans, 55 most likely normal. Would have to see what your gauges are reading to let you know for sure. The orifice tube you are looking for is in the high side A/C line near the evap core. Look for a place where the line can be undone, with dimpling to hold the tube in place.
Jun 09, 2009 | 1998 Chevrolet Cavalier
Refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSL25JFPBS Side by Side Refrigerator Logo
95 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
