Question about Dell Latitude CPX-J Notebook
How do you take the hard drive out of a dell latitude cpx J650GT
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
To remove the hard drive from a Dell Latitude, look at the side directly OPPOSITE of the I/O jacks (Headphone, mic, input/aux) side. You will see one small screw in the middle of a tray. Once you remove this screw, you will be able to pull this tray (hard drive caddy) out from the laptop. The hard drive will be in this tray. If you are replacing your hard drive, remove screw(s) on the bottom of the tray to remove the hard drive from the tray and be sure to also remove the interface adaptor, attached to the pin end of the old hard drive and place on new hard drive.
mister1763
Posted on May 02, 2009
    Problem Solver:
  • 7 Answers
On the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Posted on Nov 27, 2008
Older dell latitude cpx running XP. yesterday after loading firefox and a few mozzilla add ons .. today I boot to error 0 no primary hard disk found.. bios says no hdd installed ????
Hello, Jay.
Well, as the message indicates, your hard disk drive is failing or failed. Try running your diagnostics to verify (boot and press F2 or F12 repeatedly).
If the hard drive is failing, see if someone locally can help to retrieve your documents and other files by removing the drive and setting up the drive as a slave drive on another computer.
The drive would then need to be replaced. Price the same type of drive but it may not be cost-effective to use another drive in this computer.
Hope this helps.
Oct 18, 2011 | Dell Latitude CPX Notebook
My dell latitude cpx j650gt does not have recovery partition working and I neeed to restore it to factory settings. I do not have original OS discs as I bought it used.
You do know only certain models have an os image on their harddrive and it is this that is enabled with F9 whilst booting (or other key)Failing this you will just have to install from external Dvd/Cd rom etc-this is the fact.
Davey Snake!
Oct 30, 2010 | Dell Latitude CPX Notebook
External Toshiba 400GB HDD not recognized on my Dell CPx J650GT
New hard drives need to be formatted! So go into the control panel switch to classic view, ( if you are still using category view for the control panel ) open administrative tools, then open computer management. Next open disk management. In disk management your new drive will show as raw, you will be give the option of formatting the drive, select primary partition and format in NTFS.
This will then format the drive, when this has finished your new drive will appear in my computer.
Alan
Jan 18, 2009 | Dell Latitude CPX Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude C600
Yes, No problems as I put a 100GB drive in the LS model micro Latitude!
Aug 06, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Software purchase
Hello dazz_hammer,
You can put up to Windows XP. If do, I would suggest to add memory and bigger hard drive.
Or if the pc has Windows Product Key Tag, and what ever the operating system it indicates then you can re-install that operating system.
Hope this helps and good luck.
Jul 27, 2008 | Dell Latitude CPX Notebook
You might be able to get some more memory for it and a bigger hard drive. Depends on what the model number is.
Jul 19, 2008 | Dell Latitude CPX Notebook
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude CPX-J Notebook Logo
286 people viewed this question
Alun Cox
