Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Icemaker doesn't work and it was working fine. What do I need to check.
  • mc_guire_rob Dec 06, 2008
    I have the same problem. Mine stopped making ice and dispensing water. It took me a few weeks to look at it but when i finally got around to it this is what i did
    first i removed the filter and put in the bypas plug- no change
    second I shut off the supply valve and removed the line coming from the supply to the water valve. after did that i opened the supply valve-supply line- supply line was clear
    next I removed the lines from the water valve to the dispensor and ice maker. I blew into the dispensor line while my wife held the dispensor and water came out. I determined the valve was bad and replaced it.
    After replacing the valve the dispensor works fine but still no ice. I removed the ice maker and the fill tube looks clear How do I check the fill tube? What else can i look for before i replace the ice maker unit?
  • 89 Answers
Look at the "fill" tube that fills icemaker with water. If it is frozen, replace water valve located behind fridge in compressor department, hint: it is blue... If not frozen up, it may be the icemaker... It's either the icemaker or the water valve UNLESS your ice bucket is located in the door, then it could be the "optical" computer board eye that "see's" accross the ice bucket....
Posted on Dec 02, 2008
Kitchenaid icemaker
Hi, you need to provide more details. Does the icemaker power on when its put on and doesnt make ice or it doesnt power on at all? More info is needed pls
May 05, 2013 | Kitchen Appliances - Others
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
Whirlpool ref fan problem model no wbtxnwfwto1
did you check the fan motor with a meter to see if it's good?also the model number you sent doesn't show up,is the freezer cold?if the fan motor is checking good with meter you could have a bad or loose wire.send back info and we'll see what we can do.
Jul 29, 2012 | Refrigerators
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
127 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
