VCR to TV setup needed
I bought an old Sharp VCR . Its a VHS HQ VCA503.
I'm not sure how to hook it up. Its just the TV and the VCR. I have the red, white, yellow thing on the back of the TV but the VCR only has two yellow and two white holes and no matter what combo i use I'm not having any luck.The screen just stays on the TV and gets fuzzy.When I hit the TV/VCR button it clears right up again, and the VCR does Rewind, FF, etc so I think I just have the wires wrong.Thanks in advance. Doreen
    Novelist:
    Champion:
  • 275 Answers
Doreen, it is a simple job. At the back of the VCR you will find two sockets mentioned Video Out and Audio Out. Put the yellow plug in Video Out of VCR and the other end of this cable will have another yellow plug, which you put in the Video IN (PUT) of the TV. Take the White plug of the cable and put it in AUDIO OUT of the VCR and put the other end in RED AUDIO IN(PUT) of the TV, (Older VCRs like yours did not have stereo sound capability, and so there is only ONE Audio OUT from the VCR. )
Now, put a tape in the VCR and hit PLAY. Switch onthe TV and select AV1 or AV2. You should be able to get Picture and sound.
Posted on Nov 28, 2008
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Having trouble hooking old VCR up to new LG TV and Integra Receiver. Feel like I'm missing a step...
Look at the back of the tv. What is it labeled at where you plugged the VCR into. Should probably say composite in. After that's verified, go into the tv menu and make sure you have selected composite input. Should be no need for any settings on VCR, it has to be settings on tv
Jan 11, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
I need watch my vcr tape on vc a556
Most likely you will need a scan converter to change your signal from a Video to a VGA. The signals are mismatched.
Aug 31, 2012 | Sharp 19 Micron 4 Head Vcr Vhs Cassette Hq...
OLD SHARP VC A55HM 4HEADS VHS HQ
look for a tv monitor button then push it!
Jan 01, 2009 | Sharp VC-A554U VHS VCR
I can't hook up the vcr
I would strongly suggest connecting a plain, coaxial cable wire from your sat box to the the ANT IN of the VCR. then use another coaxial to run from the ANT OUT of the VCR to the TV. Then you can change your TV to channel 3 or 4 as appropriate.
If you have a newer digital satellite receiver, this setup may not work. In that case, use two sets of red/white/yellow cables - 1 set will run from the out of the satellite receiver to the audio, video IN of the VCR. The second set will run from the audio and video OUT of the VCR to your TV. Then change your television to Aux 1, aux2 or whatever channel that corresponds to the red/white yellow.
Have fun!
-Tha Mp3 Doctor
Dec 31, 2008 | Emerson EWV603 VHS VCR
Hooking up my VCR
OK If you are running cable you would plug cable box into VCR then VCR out to the TV input red/white/yellow/ or a coaxl cable (like the one the cable companys Good luck and Thank you for using FixYa.
Dec 17, 2008 | Emerson EWV401 S-VHS VCR
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
222 people viewed this question
Top Televison & Video Experts
Electro Med Services...
