Question about Linksys Wireless-G WRT54GS Router (e125894)
Software won't install, keeps getting a #322 error.
Running XP, my server in Hughes Net. Trying to get my other computer on wireless. My other is ready, just can't get the G configured saying the router is hooked up wrong. Tried switching cables...nothing. I am able to get on line with the parent computer. Just can't finish loading the filmware or software.
  • 1 more comment
  • JOTTE Nov 29, 2008
    setting up the router using the software installer. I Get the 322 error when I switch the cables to the new router. I have lights where cables are plugged in.
    The only wild card is I had a slower linksys router prior to the new one. I'm wondering if that's part of my problem
  • Anonymous Dec 13, 2008
    im traing to insatall a new router to my computer. i have cable internet and the ithernet cable that comes from my modem it is conected to my router on the "internet" slot and then it has 4 other slots my computer is conected to the 1st slot, but error 322 apears: New Router or Gateway not Detected. what do i need to do?
  • Anonymous Jan 20, 2009
    I have the same problem as the rest Error 322 on step 4.All of the suggestions are way over my head,you have to talk to me like I am 2 or I wont get it. ;)
  • 340 Answers
Hi -
Reset you Linksys to factory default,
press and hold the reset button for a few seconds, at the rear.
Then, connect via a cable (NOT WIRELESS, use your perent computer) and set your security again.
Remember admin password :-)
then set the security on your other computer with the same as the router
Then, I recommend downloading the latest firmware and install that.
Download the latest firmware from here:
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109974&packedargs=sku%3D1121874580098&pagename=Linksys%2FCommon%2FVisitorWrapper
Need additional help write a comment, and I´ll be back :-)
Other vice, vote "FixYa" if this was sufficient.
/Teis
Posted on Dec 07, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
I ended up not using the CD to complete the setup. I ended up doing the setup manually as far as the network card masking and it worked fine.
Posted on Dec 15, 2008
Driver won't work in windows server 2003
Somebody who need windows key click: www.vanskeys.com to got. here i got a working key on my windows about activator. and after i used my windows works properly. hope it help you.
Jul 06, 2012 | HP OfficeJet 6700 Premium e-All-in-One...
Problems with setting up wireless router wrt310n, wireless printer Dell 968W, Dell XPS laptop and Hughes net
Try reseting the wireless router, theres a reset button hold it down for 30 seconds.
Oct 05, 2008 | Computers & Internet
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
The SMTP server returned an error. Account: 'pop.012.net.il', Server: 'smp.012.net.il', Protocol: SMTP, Server Response: '-ERR Permission Denied', Port: 25, Secure(SSL): No, Error Number: 0x800CCC60
Most SMTP-servers will give "permission" to be used only when your computer is connected via an IP-address assigned to you (statically or dynamically) by the Internet Service Provider.
So, if you are using wireless Internet access, maybe provided at some retail location, rather than connected by Ethernet cable to '012.NET.IL', or wirelessly within your own home, using your own wireless router, you will get this error-message, when you try to "send" E-mail.
Feb 28, 2010 | Microsoft Windows XP Home Edition
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
Booted off aol
that means either AOL or the poker gameroom server is having a problem.
you can get the website fromt the URL. when you are at the game room.
get out of AOL and just type in the URL, and go direct.
if you still have the same problem, then it is the gameroom server.
not much we can do, expect for you to find a another poker gameroom.
Nov 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54GS Router (e125894) Logo
1,480 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
