Question about Aiwa AV-D30 Receiver
AIWA AV-D30 Unit lights but no outpoot to speakers or Phones.
  • gnvs06 Jan 30, 2009
    Mine did the same thing while I was playing the Xbox a while back. I hate to buy a new one if I could figure out the problem but dont know where to start.
3 Suggested Answers
  • 5 Answers
SOURCE: Speakers started buzzing.
It sound like your getting AC noise, chances are you have some dried out capacitors
Posted on May 17, 2006
SOURCE: don_humo
los parlantes no aguantan la potencia del equipo y hace saltar la proteccion del mismo apagandolo para no quemar el amplificador.
Posted on Jul 06, 2008
gopakumarg43
  • 69767 Answers
SOURCE: can I use 6 ohm speakers on my 8 ohm aiwa
Hello
You can use 6Ohms speaker in place of an 8Ohms speaker. No damage will occur to the set, but the quality of sound output will be a little bit less and the output will be a little bit high. OK.
Posted on Mar 31, 2011
Can I use 6 ohm speakers on my 8 ohm aiwa av-x300?
Hello
Mar 31, 2011 | Aiwa AV-X300
My av-d30 was orking one day and the next day it wouldn't power on is there a fuse or breaker switch somewhere?
There should be one either on the back of the unit or inside the unit on the C-board.
May 31, 2010 | Aiwa AV-D30 Receiver
I turn the unit on and it works for about a minute then powers down. The red light stays on. If I hit power button again it works but for less than a minute and it powers down again. Any suggestions?
try to check speaker wiring connection for possible short ckt. also check speaker itself, this amplifier have protection ckt that make unit off soon as short ckt detected.
Apr 13, 2010 | Aiwa AV-D67 Receiver
My aiwa av-x200 click right off when I turn it on, Im thinking it is a blown fuse or something, anybody fixed any receiver with this problem?
The unit is going into protection mode. There is a fault detected in either the power supply or an overload on the output circuitry. Remove all connections to the amp (ie speakers, dvd players etc etc) Turn the unit on. If it still turns off the problem is internal and should be looked at by a qualified technician.
Feb 09, 2010 | Aiwa AV-X200
Aiwa receiver won't turn on
Hello:
This looks like its displaying the Time format. Try disconnecting all speaker one a time and turning on the unit to see if it turns off. Disconnect one speaker at a time and turn the unit on. If it turns off with only one speaker conn then this speaker is your problem. Amps will shut down if a speaker goes bad. Another thing to try is disconnecting all inputs and speakers from the unit and see if it stays on. Then reconnect them one at a time while watching what the unit does during power up. Also you might want to open the device and check for blown fuses. Check for any speaker terminal wires touching each other if so it will shut down thinking there is a short.
Nov 30, 2009 | Aiwa AV-D50 Receiver
Aiwa AV-DV75
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
Jan 02, 2009 | Aiwa AV-DV75
Don_humo
Jan 15, 2008 | Aiwa AV-D30 Receiver
Dec 13, 2005 | Aiwa AV-DV70 5.1 Channels Receiver
Aiwa AV-D30 Receiver Logo
35 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
