Question about Ovens
Kenmore Gas Oven not working
I have a Kenmore Gas Range Model #79075721991 I would say it is at least 15 years old? It came with the house when we bought it. The burners lite with no porblem, but the oven will not not turn on? Could it be a Pilot out? Not sure what kind of Ignition it has? Any help would be greatly appreciated. I am hoping I do not need to replace the whole thing.
Thanks!
Michelle
  • nicdanh Nov 27, 2008
    Thank you for your quick response! So, do I just go under with a match and hope it lights? I did remove the warming tray and there is some sort of thing connected to the gas line. I get a little nervous around gas.
    Thanks
    Michelle
    Sergeant:
  • 359 Answers
IT POSSIBLY DOES IF SO IT WOULD BE UNDER TH BOTTOM PAN USUALLY IN THE BOTTOM OF THE OVEN , YOU WILL NEED TO LIGHT IT WITH A MATCH (AFIREPLACE MATCH WORKS BEST ) LET BURN FOR A FEW MINUTES TO MAKE SURE IT GOING TO STAY LIT BEFORE YOU TRY THE OVEN .
Posted on Nov 26, 2008
I turn on the stove and about a minute later it shakes the side of the house and lights. Heats well and works fine after doing this. It's a kenmore and about thirteen years old. What could be happening.
There could be expansion issues with the oven. When the oven heats up the sides or bottom could be flexing causing this. If it is a gas range with an oven igniter it could be the igniter is getting weak and the gas is not lighting right away and causes a small explosion when it does light. If it has an igniter look to see how bright it is. If it is orange in color it is probably the problem. They should glow a bright yellow. If the igniter has never been changed it could be the problem. Hope this helps.
Feb 17, 2014 | Ovens
Bottom of kenmore oven pitted
Baked on debris causes this. The spots are from food sitting there without being cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 08, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Erratic oven temperature
The ignitor is probably weak and not relighting when it needs to. Replace the ignitor.
Sep 05, 2009 | Ovens
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Replacing oven bottom liner for Kenmore oven
about to do the same for a friend - hers has two visible screws through the floor at the back of the oven. the new plate has several additional holes. i have not yet removed the old, but looking at other google entries, i may just need to take out the visible screws.
not sure of the model, but it is a free-standing kenmore gas range.
gary
Apr 09, 2009 | Kenmore Ovens
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
87 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Oven Expert? Answer questions, earn points and help others
