Question about Sony Network Walkman NW-A3000 MP3 Player
Water inside screen
Is it safe to remove perspex front and if so how?
  • 8,596 Answers
It is not safe - sorry, dude
Posted on Jul 06, 2008
How do I remove instructions jammed in front?
Sentry Safe Not Safe - YouTube
? 5:14
https://www.youtube.com/watch?v=CmAQN6hJ1wQ
Jan 21, 2012 - Uploaded by lolitsmexd
Video blogging about Sentry Safe and how easy its to break into one. For a Fire Proof and Water Proof safe ...
Open a sentry 1610 safe - YouTube
? 3:46
https://www.youtube.com/watch?v=vdI6m24GIKs
Mar 9, 2014 - Uploaded by Brad Snoke
There is an actuator inside the front that seems to fail... ... NewSentry Electronic Fire Safe Opened in Seconds .
Nov 14, 2015 | Sentry Fireproof Safe
How do you fix prius defrost
I can't say if yours is broken or not but I know mine reacts similar to yours. I put it down to the top screen being glass and the bottom one being perspex/plastic. I also notice that the gap between the elements is wider on the bottom screen, so maybe the perspex heats up quicker than glass?
Aug 28, 2014 | 2009 Toyota Prius
LF COMES ON MY FRONT LOADER LED SCREEN
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Here is the valve to order in case it is faulty.
Nov 09, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Error f-20 only in the wash cycle
Hi Valleri:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | Kenmore HE2 Plus Front Load Washer
Finger print marks on the screen
you mean clean the screen ??
any solution designed to work with perspex or acrylic will be perfect. try "uvex" products or those designed for perspex motorcycle crash helmet visors.
i had a few rear projection tvs over the years and normal everyday household polish didnt do mine any harm at all.
also a damp cloth will remove fingerprints but will leave smears. so skip the washing stage and just use an everday household polish without beeswax in it ,cos that puts a waxy coating on it. stay away from any alchohol based products.and if in doubt try the uvex stuff
http://www.envirosafetyproducts.com/product/Uvex-Clear-Lens-Cleaning-Solution-16-ounce-Pump.html available outside the us as well, made for cleaning safety glasses,
Feb 07, 2010 | JVC HD-61Z575 61" Rear Projection...
Dirty screen. What should I clean with?
any solution designed for acrylic or perspex screens will work just fine.
motorcycle helmets have perspex visors , so a solution designed to clean motorcycle visors will be ok too.
have a look for "uvex " its both a cleaning solution and it also comes in wet wipe type tissues for safety glasses cleaning and lcd/plasma screen too.
Feb 07, 2010 | Samsung Televison & Video
F20 error code???
Ok, I found 2 solutions for this problem, I tried the first one, and it really seemed to work, but I think I will do the second one too.  First, if you have metal flood safe hoses, you need to look for debris blocking the filter at both ends.  I kept checking the screens at the washer end and not seeing anything, but there was debris located at the water supply end, stuck in the flood safe device that is in the metal hose.  Also, Flood safe hoses say to turn the water on to full pressure, but sometimes that can activate the flood safe device, so only turn your water supply on half way.  Make sure that the hoses are on right as well, the flood safe device needs to be at the end with the water supply, not the washer end.  You will be able to see the device (it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, it is located in the front just under the front bottom removable panel.  If you have a pet in the house, definitely check this out, a lot of hair gets stuck in that.  Just unscrew the front bottom panel, and then it is right in the middle at the bottom, a cone shaped filter.  Get a towel, because there will be water in there, too. Check out this link with pictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
Feb 08, 2008 | Kenmore Elite 45986 Front Load Washer
Sony Network Walkman NW-A3000 MP3 Player Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
