Question about Xerox WorkCentre M15i Laser Printer
Printed image The ink creates the image on the paper, however, it does not bind to the paper and easily rubs off. Is there a temperature setting for the fuser unit that 'sets' the ink?
  • 161 Answers
There is no temperature setting for the fuser unit. Either your paper is too humid (it also curls when coming out of the unit). Or your fuser unit is bad.
Posted on Oct 02, 2007
Can use a glossy paper?
If the glossy paper is rated for the printer you are using yes. Never use paper that is only rated for inkjet in a laser printer. Many special inkjet papers have coatings that will melt or break down due to the heat of a laser jet and may damage your printer.
Jan 14, 2015 | Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
Printed pages have blank lines every three or so lines.
Hi
It might be clogged ink or ink dries up. If the ink is new try to rub the print nozzle in a plain paper with rubbing alcohol until ink flows and run the print nozzle cleaning for 2 times and then try to print again. Regards
Jun 28, 2011 | Dell 926 All-In-One InkJet Printer
Hello, i'd like to ask for advice. I have this one problem with canon ipf 8000, we've been using Schoeller H 64160 photopaper for poster printing with no problem. But recently we got different type of...
iI would check your paper type setting. you are working with a liquid type of ink and water will effect it. check the drying time of this ink. set your paper type to the set the type most suitable for this paper. try heavy gloss. you will find it under paper settings in the main menu. If no luck refer back to the ink and its compatibiliy with your ipf 8000. now if these are a recharged cartridges. you should change to the oem. meaning" original engineering manufacture".
Apr 09, 2017 | Canon imagePROGRAF iPF8000 Printer
I printed wedding invitations and now if you rub the invitations the ink rubs off. Is there any way to get the ink to set (or not rub off) now that I have finished printing everything!!! Help I need to...
Maybe someione is trying to tell you something LOL.
The time to figure this out is *before* you print invitations as a DIY project. There's a set of photographic inks and paper that keep the product from smearing and there's always the commercial printer. Unfortunately for you, you get to learn this lesson too late. Here's the reading material on inks http://www.hp.com/products1/printpermanence/pdfs/finals/Water-resistance_article.pdf
Carl
Oct 02, 2010 | Office Equipment & Supplies
On anything other than plain printer paper, the ink tends to rub off the printed page - really a problem with labels and envelopes. I have tried changing the printer settings for these items, but it does...
You may need a shop to increase the fuser temperature. You also may just need a new fuser. In printing preferences you need to make sure you're telling the printer you're using envelopes or labels. When the toner rubs off, the fuser is just not hot enough.
Nov 05, 2009 | HP LaserJet P2015 Printer
PRINT IS BLURRY
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Unfused Image
Pressure roller is worn out. Needs replacement
Mar 28, 2009 | Canon MF8180C Color Laser MFC Printer
Ink rubs off or prints double/messy
Sounds like your fuser is getting ready to stop working. Your fuser creates the heat so the toner from the cartridge is baked onto the paper as it passes through, your toner is rubbing off, so you could try cleaning, but I'm sure it'll be a new fuser, or possibly a fuser roller. Your owners manual has all the information and step by step trouble shooting guide to let you know.
May 23, 2017 | HP LaserJet P2015dn Printer
Xerox WorkCentre M15i Laser Printer Logo
89 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
