Question about HP LaserJet 4 plus Printer
Printer is dark
My hp laserjet 4 is printing too light, and I've heard that it may be something with the software???
  • 1 more comment
  • Justin Goldberg Dec 02, 2008
    Thank you for the response. Actually, now that I've checked the printer myself, as it turns out, the text is printing kind of light, but there are grayish band in the background, independent of the text itself.
    To clarify, the bands are not totally straight lines, but generally vertical smudges, that up close look like carbon copy paper smudges, or a charcoal relief, if that helps.
  • Justin Goldberg Jan 09, 2009
    It needed new toner.
  • HP Master
  • 4,338 Answers
Go to Start > printers and faxes> right click on the laserjet4 icon>
properties > click on printing preferences on the first page > click advance on the next page > under Graphics, you will see print quality. Change it to either 600x600 or 1200x1200. The higher the number, the darker the print.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
  • JDTec
    JDTec Dec 02, 2008
    Do this:
    start a print job. then as it picks up the paper , power off the printer when you feel that the paper has reached the toner cartridge but has not started to go into the fuser section. Open the printer and take out the toner cartridge. Look at the paper, is the smudges or faded background is there then the problem is the toner cartridge. It it looks ok up to that point, then it is the fuser, which would need to be replaced.
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Hp laserjet 3050 all-in-one printer software will not load on my windows 7 64 bit laptop.
It Depends on if the Fax is available for your region, Roll back all driver and start the installation afresh and be sure the option of Choosing Fax is highlighted.
Dec 10, 2012 | HP LaserJet 3050 All-In-One Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
I"ve HP Laserjet 3005x Printer
Try a different toner cartridge
Feb 24, 2011 | Office Equipment & Supplies
How to make print more dark laser printer hp 1005
go to start menu, choose printer & faxes, click the printer icon properties and find the printer resolution to adjust the dark printing capability
Dec 12, 2010 | HP LaserJet 1005w Printer
I put in a new toner cartrige in my hp laserjet4 and it does not print very dark, whats the problem.
did you peel off the tape from the cartridge before installing it ?
when you want to print something, don't press the print button, select print review and selkect properties, make sure its not printing DRAFT --select fine
have you tried the print test
Oct 18, 2010 | HP LaserJet 4 plus Printer
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Jan 28, 2009 | HP LaserJet 1300 Printer
Print quality
Change the PCU cartridge.
Mar 01, 2008 | HP LaserJet 1020 Printer
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
HP LaserJet 4 plus Printer Logo
107 people viewed this question
Ben Johnson
