Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
What is the hot key for getting my Westinghouse monitor to display from my laptop?
Activition key
Posted on Nov 28, 2008
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Where is the hot key
Hold the FN key then look for a picture that resembles a monitor
in the top row F keys probably F4.
That transfer displays or use them both.
Jul 19, 2014 | HEWLETT-PACKARD G56-129WM Laptop PC
Laptop is connected to the external LCD monitor, the monitor is on but screen is blank
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external monitor source
3) External monitor source ONLY
Hold the Fn key down, and tap once on the F5 key.
Hot key through until you find the setting you want.
Release the Fn key
Regards,
joecoolvette
Apr 16, 2013 | Toshiba TECRA M9 Notebook
My Dell Latitude D820 has many problems.... The biggest one is that I came home from work to turn it on, and the screen is black... When it turns on, it is completely white. I am so upset! I just got this...
Screen issue:
It sounds like either the lcd screen or video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays ok that proves your video card is ok and your lcd screen is the problem. If the external monitor displays the black or white screen like your lcd screen then your video card inside the computer is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Laptop hot:
Some laptops and the ac adapter get very hot. If the laptop is not shutting down, then it is not overheating, so don't worry about it. You can buy a laptop cooling pad that has fans on it and it plugs into one of the usb ports on the laptop. The laptop sits on it to keep cooler.
Your battery is probably dead so that is why you can only power it up using the ac adapter power cord. Once the power cord is removed, the laptop will turn off. Batteries only have a useful life, and after that, they have to be replaced.
May 21, 2012 | Dell Computers & Internet
I am getting a no signal input on my Westinghouse LCM-w3. It was working fine two days ago and it is properly plugged into my laptop.
It can be that your PC's video card is not working, you should try this montior with another PC or try another monitor with this PC first to narrow down the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 19, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
No input signal at the monitor when I plug it to a laptop, only when in safe mode I can see the desktop of laptop
When you power up the computer press F8 key then you can see safe mode and other menu enter in "enable VGA mode"
Then go to start ->control panel ->display- settings.
Change screen resolution to 1024*768
Then apply and ok.
then restart then check.
If you still get blank screen then enter in safe mode and uninstall graphic driver from control panel -> add remove program wizard or device manager.
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Westinghouse L1975NW Monitor
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
No display
I bought an Acer V193bm. If I manage to get the Westinghouse fixed, I'll post about it.
Jun 16, 2009 | Westinghouse L1975NW Monitor
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
52 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
