56"rca hd tv blowing fl231 convergance fuses - Televison & Video
  • 8,617 Answers
Replace DL231, CL230 , Fl231 then reflow the solder on the Flyback and vertical IC and that should solve the problem. You can get replacement parts at the following link .
http://servicemanuals.vstore.ca/
Posted on Nov 26, 2008
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
My rca hd '52" tv has a bow in it & colors dont line up
Blowed Fuse FL231 will be on right handside of FBT flyback Transfomer there is 3 of them in a Roll small brown looking caps But they are Fuses it will be the one in the Middle Located on your Deflection Board which is the Bottom left hand side Board. www.Partstore.com for Fuse
Dec 21, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Hello please tell me how to reset the convergence
Go to menu then setup if you do not see convergence on menu then you have a blowed fuse FL231 it will be on deflection board its the bottom left board has FBT on it and on the right side of the FBT flyback transfomer is 3 Fuses in a roll they look like small brown rectangler caps But are Fuses it will be the one in the middle Call Partstore.com 1-866-925-7278 or visit their website.
Nov 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost convergece and not on the tv menu
Simple problem to fix for a professional; pretty hard to do yourself. There are bad connections on the flyback transformer and a fuse is open. Where do you live; i'm due for a road trip.
May 12, 2009 | RCA R56WH76 Projection Television
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
Apr 18, 2009 | RCA HD56W66 56" HDTV
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Oct 02, 2008 | RCA HD56W66 56" HDTV
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
