Question about Lexmark X5150 All-In-One InkJet Printer
How to unlock the scanner
Printer does not work properly and this messages come up in the window
"unlock the scanner and then press power.
Thanks
    Scholar:
  • 174 Answers
Remove both cartridges from the printer.
Move the red lock switch (at the back of the printer) from the down position to the up position, and then move it back to the down position.
Unplug the printer and turn it onto its left side.
Then return the printer to the upright position and reapply the power supply.
Attempt this fix twice and then try to print and scan once more.
Posted on Nov 26, 2008
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark x6170 How do I unlock the scanner?
This is the user manual for your printer...
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
Sep 16, 2009 | Lexmark X6170 All-In-One InkJet Printer
Unlock
According to the manual, it's on the bottom of the scanner. It's a slide switch that should be moved toward the picture of the open padlock.
Jul 18, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Where do I find the unlock switch to unlock the scanner.
Hardware is defective. Call lexmark tech support & get a 20% discount to buy a new printer 800 332 4120
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Error Message
The scanner lock is used to keep the printer from being damaged when it is being shipped. To unlock it, just open the printer and push the scanner lock down. When you lift up the scanner unit, (like what you do to get to the cartridges) the scanner lock is on the left of the underside of the scanner unit. You can get the manual from the Lexmark Website at http://www.lexmark.com/publications/eng/x6100/index.html
Sep 17, 2007 | Lexmark X6170 All-In-One InkJet Printer
Scanner not working
Samsung can be cheeky with support i have found and not as helpful with tech help. Instead of going off in tiny circles with unlocking etc, i would go for the quick fix and suggest your scanner may not have installed properly when you installed it. As you have installed the drivers again with no luck i would even suggest goint to samsung web site and downloading new updated drivers for your printer to eliminate corrupt drivers. Does you pc register the scanner being there? Go to control panel, hardware/ printers, find your printer and check all the drivers and whether scanner is actually present on the pc here.
Aug 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
remove the lock from scanner,switch on scanner and restart you computer. bye
Oct 29, 2006 | Dell A960 All-In-One InkJet Printer
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
