Question about HP Pavillion ZV6000 Notebook
Expansion bay not opening
When I press button to right, the drive will not open. It always has before. How get it to open?
  • TrytoFix01 May 11, 2010
    Is this the cdrom drive?
You dont have anything inside. Me too. try to open with your nail
Posted on Jan 05, 2009
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
MY EXPANSION BAY IS STUCK
Sometimes the opening/closing mechanism in CD/DVD drives fails. If nothing is physically blocking it from opening then you will need to replace the drive.
Jun 25, 2012 | Computers & Internet
How to replace the motherboard in a Compaq D510 computer
The Compaq D510 desktop computer uses a U-ATX size motherboard that is smaller than the standard ATX size. If the motherboard on your Compaq computer has stopped working or you want to upgrade to a different motherboard with different expansion slots you can open the case and replace the motherboard.
to replace the motherboard, just follow these steps:
  • Double click on the "Smart Cover" icon on the desktop. Enter in the Smart Cover lock code if you have set one up and click on "Unlock" to disengage the hardware lock that prevents the case panel from being opened.
  • 2
    Click on the "Start" button at the bottom toolbar of the desktop and choose "Shut Down." Unplug all of the cables from the back of the computer once it has finished powering down.
  • 3
    Set the Compaq computer case on its side and remove the two screws connected to the top and bottom ends of the case panel. Slide the panel to the left and pull it directly off the case.
  • 4
    Disconnect the SATA cables running from the power supply, drive bays and processor fan to the motherboard. Remove the screws holding any expansion cards you may have previously installed into the AGP ports on the lower right side of the motherboard and then pull the cards out.
  • 5
    Pull back the clamp holding the processor fan on. Pull the fan and then the processor off of the motherboard. Pull off the RAM modules from the motherboard.
  • 6
    Remove the screws holding the motherboard into place and pull the entire motherboard directly out of the case. Check the orientation of the replacement motherboard and make sure the USB ports and AGP expansion card slots are facing towards the back of the case. Lay the new motherboard down into the case onto the mounting screws sticking out of the bottom panel.
  • 7
    Place the processor back into its socket on the motherboard and connect the fan on top. Snap back on the fan clamp. Place the RAM modules back into their slots. Re-connect all of the SATA cables to the drive bays and power supply.
  • 8
    Set the side panel back onto the case and re-connect the case screws. Connect all of the cables into the back of the case and power the computer back on. Wait for the operating system to load to make sure the motherboard is working properly.
  • 9
    Navigate back to the Smart Cover program, enter in the password, and press the "Lock" button.
  • Dec 06, 2011 | Compaq Computers & Internet
    How can I change the region on my Toshiba SD K860?
    1. Power on the DVD player
    2. Press the Open/close button on your remote control to open the drive tray and remove any disk
    3. Press 2403960
    4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
    5. You will see a 9 (region-free) on the TV (right corner)
    6. Press the Open/close button on your remote control to close the drive tray
    7. Power off the DVD player
    8. Power on the DVD player and it is region free.
    May 22, 2011 | Televison & Video
    How do i get the cd drive to open on an acer aspire ax3400-b4802??? as if i wanted to put a cd in it...i can see where it goes but theres no opening?
    It depends on the drive model but there is usually a 'button' on the drive door: while the unit is power up, just press it to open the cd/dvd drive bay.
    Hope it helps.
    Apr 27, 2011 | Acer Aspire 5100-5033 Notebook
    My expansion bay will not open.
    Try to open the lid above the button with your nail,you'll see a metal plating covering the inside of it.The expansion bay is to add another drive, like a Cd/Dvd drive. Just don't worry about it too much,when you ad the new drive,you can take the plating off.Whoever adds the drive will open it up,too
    Oct 09, 2010 | HP Computers & Internet
    The CD drawer doesn't open...I push the button and it sounds like it's going to pop the lil drawer open...nothing happens. Help pls...
    take a paper clip and streighten it out in a long wire - you should see a hole in front of the cd rom by the drive bay press it in the hole and push the drive open
    here is a video
    http://www.youtube.com/watch?v=kscn5_XG2oE
    Dec 27, 2009 | Compaq (120192-B21) CD-ROM Drive
    Multibay/cd/dvd access
    If you look on the side edge of your laptop (more than likely the right side) you should see a CD/DVD drive bay with a small button. Just press that and it should pop out enough for you to finish pulling it out.
    The other way to do it is to open "My Computer", right click on the icon that says "CD/DVD" and select "Eject".
    Let me know if that helps.
    Mar 11, 2009 | HP Compaq nc6000 Notebook
    Recording
    The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
    Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
    Problem recording
    Jan 26, 2007 | EverFocus EDSR1600/500
    HP Pavillion ZV6000 Notebook Logo
    184 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
