Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
Using rollers to pull fridge out for cleaning
I don't know how to use the rollers that I "thought" this fridge had so I can pull it out from the wall to clean. I read the "user manual" but didn't find what I needed. It is an Amana ABB2224DEW.
    Novelist:
  • 103 Answers
Hi: Simple. Every Amana refrigerator I've seen in the last 15-20 years have brakes. In front of your wheels is a rubber disc that screws down to stop the fridge from rolling forward when you open it. You have to screw them back up a little to make it roll. If you look at your grill you will see that it is flat all the way across except for the ends they protrude forward at the ends. They usually cover the brakes. Work at the grill to find the clips that hold it in place. It will snap off. The reason for putting you through that; is the energy efficiecy, The seals work so well that you would pull the fridge forward when opening. That should work, Jeff
Posted on May 31, 2009
I have an old kenmore fridge maybe a 90's model it's an off white color probably from age and alittle rusty, it's a top freeze and the freezer works great but the fridge section can barely keep...
all the fridge does is the freezer gets cold and the evap fan blows cold air from the freezer down into the fridge section,so open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,also the drain can be blocked and it freezes up the air ducts so the air can't circulate down into the fridge,is there water under the bottom crisper draws?if so the drain in the freezer is blocked,you have to take everything out of the freezer,remove the back wall,melt out all the ice and clean out the drain under the evap coil.i use a steemer to clean out the drain,if you don't have a steemer you have to melt out the ice in the drain with the hair dryer,then get like a turkey baster or anything that can blow down into the hole,pour hot water into the drain,if it drains out then you're done,if it doesn't keep hitting it,another thing is touch the inside back wall of the freezer,if there's like frost or like snow covering the back in side freezer wall you have a defrost problem,bad defrost thermostat,heater or timer,the last thing is the door was left open,you can tell this by looking at the food packages and the ceiling and walls,if you see frozen water droplets on your food packages or on the shelf or walls the door was left open and the air ducts are frozen,you have to melt the ice out of the air ducts.so open the freezer door,listen for the fan,no fan could have a bad fan motor,look for ice on back inside freezer wall or frozen water droplets,the door was left open or you have a defrost problem. also when was the last time you vacuumed out the coil unless it's on the back wall,if the coil is behind the bottom kickplate vac it out that will make a big difference.you can get back to me and let me know what you find or melt it out with a hair dryer like i said.good luck and let me know what you find.one more thing,if your ice cream is not staying hard just soft you could have a leak in the sealed system,but if i were you i wouldn't put any money into that machine,if you change it out you'll save money on your electric bill and usually once something on those old dogs starts to go wrong it's not long before it totally dies
Sep 22, 2011 | Kenmore Refrigerators
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
Fridge comes on frequently.
The best thing to do is pull it away from the wall. Get the back bottom cover off (probably, card board). Get a good vacuum and clean the condenser coil of any dust....Getting the condenser coil as clean as possible, then replacing the fan motor would be your best option to get the fridge to run quieter and less frequent.
May 03, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Broken crisper roller tracks on KitchenAid frdge md# KBRS22KFWHO
fixya doesnt sell products or replacement parts search on line using make and model for part or notify manufacturer for a parts distributor in your area
May 18, 2017 | Frigidaire FRS3R5EMB Side by Side...
Lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Water dripping into fridge from freezer.
Hi. thanks for the question. You have a problem with the drain tube, from the freezer ,to the tray underneath the fridge .Best way to clean. Turn power off to fridge. Let defrost for 24. HRS . pull fridge from wall remove back panel clean all coils locate the drain hose at the drain pan clean . Thanks the appliance doc
Sep 30, 2008 | GE Refrigerators
My fridge is not cold enough and the freeze is colder and has ice
hi. thanks for the question. the drain tube that goes down to the drain tray is clogged. turn fridge off .pull fridge from wall. remove back panel clean all coils. let it thaw with doors open, it will thaw quiker. when thawed, clean the drain tube. this will solve the problem. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dark Smear Won't Go Away
It Sounds like you may have damaged, or in some way stained the Fuser Roller.
The roller is situated on the top of the unit under the smaller opening flap towards the rear. release the blue levers and examine the surface of the orange roller, chances are the roller is marked.
New Fuser units are available from a number of UK sources but are pricey at around £100 (100k copies per unit).
The other possible cause is if you are using a refilled black toner cartridge. Dell toner units don;t like being refilled more than 3-4 Times and often leave a "ghost" mark on the page. try a new dell toner in the unit and see if ithat helps.
May 23, 2008 | Dell 3000cn Color Laser Printer
Roller on Dirt Devil hand vac won't turn
Usually the ends will pull off so you can clean them. If not, then you will have to replace it.
Mar 23, 2008 | Vacuums
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
1,283 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
