Question about Samsung 710V 17" LCD Monitor
Samsung 710v tft monitor
Can anyone please help ,,,my samsung 17inch 710v sycmaster ,,,has developed two fingerprint sized cloudy spots on the display ,,wich are quite annoying when im using it,,,its not dirty marks ,im convincing myself my little girl has pressed her fingers on the sceen,,,also when i have a dark background the marks apear light or lighter,,please help if you can ,,its worrying thanks,,fiona
  • Samsung Master
  • 9,156 Answers
These "pressure marks" can only be fixed by replacing the LCD panel, which is not economical. The panels usually cost as much as or more than the monitor itself, unoless you can find a good used one.
Posted on Jan 12, 2007
SOURCE:
Cant find drivers for my smasung sycmaster 152N moniter tried 4 sites now
you can find the display drivers in the website of the proccessor you purchased
for more information you can log into samsung .com
PLZ vote
Feb 26, 2011 | Samsung SyncMaster 152N 15" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Samsung 710v test good
For anyone having this problem i suggest to get a manual from asnerejas. His notes helped me out totally.
Its not something you would spot looking at its inside...
Feb 19, 2009 | Samsung 710V 17" LCD Monitor
Where is the source button on the samsung 710v
the 710V samsung monitor has only vga analog input. so there is no source button
Samsung 710v 17'' lcd problem
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Dec 14, 2007 | Samsung 710V 17" LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Samsung 710V - controller box
your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Oct 20, 2007 | Samsung 710V 17" LCD Monitor
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
197 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
