Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Viper SST 7701. I replaced the vehicle battery and now the 2007 Saturn Outlook will not start. How do I program the Viper system to allow it to start?
    Sniper:
  • 50 Answers
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Posted on Aug 14, 2009
I have a viper 7701 remote that just stopped working. Battery is new. Do I have to re program something
If it is the OE (original equipment) key fob, meaning if it is the alarm remote control that came with the original purchase of the car it should not need reprogramming. If it is an aftermarket alarm then it may need reprogramming, more information is required to answer the question.
This is a common issue and the most common problem is that the solder joints holding the battery in the proper location. If any of these are broken the remote will not function. It can be fixed with a little solder or if your uncomfortable with doing it yourself, take it to a computer repair store (they can fix it ONLY if you have a broken solder point).
Take the key fob to the closest auto parts store (aka. autozone, o'reilly's, advance) and near the counters they have a key fob testing equipment (FREE). If the remote is working a light will blink when you push the key fob button while close to the testing equipment. If the testing light shows that the fob is working but does NOT unlock your doors, it needs reprogrammed. If the testing light doesn't blink at all, repair or replacement of the key fob is indicated.
Hope this helps and good luck!
Dec 31, 2014 | 7701V Remote for Viper Responder SST Car...
How to start my truck the viper has locked the system wont start
To manually disarm the alarm, turn the ignition on, press and release the valet switch. Start the vehicle.
Jan 27, 2013 | 7701V Responder SST Remote
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
I just purchased a 2007 Mazda3 S Sport Sedan and it came with a Viper 7701 intalled. I need to know where I can download the manual to help with turning off the alarm during thunderstorms and just general...
the 7701V is actually the remote. The Viper remote start alarm system that it corresponds with is the Viper 5900.
Mar 21, 2011 | 7701V Responder SST Remote
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
The battery was taken out of the viper remote, now I can't get it to communicate with the car to lock,unlock start.
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Nov 30, 2008 | 5900 SST 2-Way Security System / Remote...
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
1,373 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
