Question about Poulan Pro Chain Saw 46cc 20"
My chain saw wont start just changed the magneto and still wont start
  • ne3144 May 04, 2009
    i have fire and gas but still won't start won't even kick
    Sergeant:
  • 359 Answers
IF YOU ARE GETTING FIRE TO PLUG TRY A SHOT OF STARTING FLUID IN AIR BREATHER BE SURPRISED HOW MANY IT WORKS ON
Posted on Nov 27, 2008
Poulan chainsaw not getting any fire?
check to see if your magneto is rusty if so clean with fine grit paper if still does'nt fire may be time to replace the magneto
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
What causes a polan chain saw to **** back when i pull the rope
Dorothyjack:
It sounds as though your magneto has gone out of timing. Between the flywheel and the drive shaft there is a small square key that keeps the flywheel from slipping on the driveshaft. The spark coming from the magneto is not causing the spark plug to fire at the exact time it is supposed to. You will need to remove the side cover from the motor, and check to see if the slot in the flywheel and the slot in the driveshaft (where the square key fits) are aligned exactly. if those two slots are not aligned (even a little bit) the saw's engine timing is off. This is caused by the chain being stopped suddenly while you are cutting (for instance if the chain pops off of the chain bar. it will be necessary to remove the flywheel (using a flywheel puller) and replace the key. then reassemble the saw making sure the chain tension is correct and that the magneto to flywheel spacing is correct.
Dec 30, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
Chain saw died, no spark. replaced the magneto, still have no spark. gaped it with a .010 brass feeler gauge. disconnected the grounding wires. could it be possible to have 2 bad magnetos. Repalcement part...
Hi, gap should be 8 thou. Try this with a new plug. Check the magnets on the flywheel. It is possible to have a faulty new magneto but not that likely. Also check that the sparkplug terminal is contacting through the high tension lead correctly. Regards Phil.
May 16, 2011 | Ryobi Factory Reconditioned 18" 40cc...
I have a Poulan Pro 295 20 " chain saw that wont start.No spark from plug.Think the magneto is bad. Model no.952-051310 . Need opinion and part no. Thanks.
Do a basic test first, remove the top cover, pull the earth cut out wire from the terminal on the ignition unit ( this will iliminate any problems with the switch, or wires ) now try for a spark, remember that they work off speed of rotation so give it a good pull, make sure you use a good clean plug, well earthed against the cylinder. If there is still no spark, you will need to replace the unit, part no. 530039143
Feb 17, 2011 | Poulan Pro Chain Saw 46cc 20"
Husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 02, 2009 | Husqvarna Chain Saw 20" Bar
Weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Mar 12, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Pro Chain Saw 46cc 20" Logo
338 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
