Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon MP800 Not recognising Ink Cartridges Magenta and Cyan
I have just purchased replacement Black 5 and Magenta and cyan 8 ink cartridges for my Canon MP800 and after inserting machine is not recognising the Magenta and cyan whereas no problem with the black.
  • 2 more comments
  • D Kelly
    D Kelly Nov 28, 2008
    My problem is similar, but it is the yellow that my printer does not recognise. When I load the yellow on it's own or with three other colours it is recognised o.k, but when I load the fifth colour that's when the error U072 comes up. Message reads:~ some ink tanks are not installed in place.
    Has anyone had this problem?...
  • sw33tp Mar 15, 2009
    Similiar problem for me. I have just purchased replacement Black 5 and the 4 pack of Number 8's and when I inserted the Black 5 and cyan 8 ink
    cartridges into my Canon MP500 it tells me it the cartridge was empty at one time and will not accept it. Is it possible that Canon refills the cartridges?
  • LeighTower May 11, 2010
    We can assume that you are using fresh Canon-brand cartridges (not refills or non-Canon inks). We can also assume your ink tanks care in the correct order, from left to right, of BK8, 5PGBK, Y8, M8, C8. And finally, all the tank lights are bright and non-blinking? If any of these assumptions are wrong, let us know.
  • Anonymous Mar 29, 2014
    leaking catrtridge when purchased. seal on cartridge not groken
SOURCE:
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Can't find where the ink cartridges are on the cannon mp830 to replace
THE INK CARTRIDGES :
This multifunction printer is compatible with all of the following ink cartridges. Here is a list of these cartridges and how they you can get them:
PGI-5 Pigment Black
CLI-8Bk Black
CLI-8C Cyan
CLI-8M Magenta
CLI-8Y Yellow
All of the ink cartridges are easy to install and/or replace; all you have to do is keep the printer ON, then open the cover it will come in the position and then unlock the cartridge which allows you to remove and replace the cartridge.
These cartridges cost any where between $10 and $15 each. But if you want a good deal, I would suggest purchasing your ink supplies from Costco Wholesale as they provide good prices on packages.
Jul 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
How to load the new ink cartridge. HP Photosmart C5140.
Replace the ink cartridges (from the manual for the printer)
Follow these instructions when you need to replace ink cartridges.
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
Jul 04, 2008 | HP Office Equipment & Supplies
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer Error
I fixed this problem by installing a new magenta ink cartrige. This makes me believe the problem is in the replacement cartridges. Of course this is not very satisfying because I had to discard a 3/4 full ink cartridge.
Oct 16, 2007 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
1,422 people viewed this question
Clive
Clive
old marine
old marine
