Question about Frigidaire FDB956RB Built-in Dishwasher
Dishwasher not cleaning.
I have a Frigidaire built in that does not seem to be cleaning. It heats and water is filling but the arms don't turn or something. I emptied the drain/catch, pulled all the components out and rinsed them etc, after I replaced them it seems the machine stopped working. Is there a seal or a sensor that pevents it from spinning? The water is not getting to the soap compartment either, the soap sits in the cup. It's as though the water sits in the bottom and then just drains out, I can hear it fill and see water in the tube but the racks are not getting wet. How can I fix this myself? Thanks
  • aecsbill Nov 19, 2008
    Water comes in but does not clean dished.Hot point
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: frigidaire dishwasher...
It is very possible that something could be obstructing the main pump. But, first. Does your dishwasher fill with enough water? When full, the water level should fill to just below the heating element. You can check this by waiting for the fill cycle to stop and the normal wash cycle to begin. Open the door and check the water level. If your dishwasher isn't getting enough water, you could have a bad fill valve, or the inlet water line could be kinked. If this isn't the case, then suspect that you might have a clogged pump. Food particles such as popcorn kernels, orange or lemon seeds, small chicken bones and glass are notorious for getting into the pump screen area and obstructing the water flow (some of the other items I have found are labels off jars, bottle top seals, twist ties, rib bones, hair scrunchies, and yes - even band-aids!). Even though some dishwasher manufacturers advertise some amazing capabilities of their dishwashers, you still need to scrape your dishes of all food particles as much as possible. This does not mean you have to pre-wash prior to loading them. Anything that doesn't get dissolved by the wash cycle and detergent will end up sitting in the pump well. If the pump isn't able to pump enough water, your dishwasher will fill normally, but the spray arms will not turn, detergent does not dissolve and your dishes will not come clean. To get to the pump, you need to remove the lower spray arm and the coarse screen (located directly under the lower spray arm). The pump well should be located under the coarse screen. Look for anything that may restricting the water flow. I hope this helps and it's easy fix for you.
Posted on May 12, 2007
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
SOURCE: Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Posted on Oct 17, 2009
  • 574 Answers
SOURCE: Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Posted on Jan 25, 2010
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
The top spray arm is not turning as best i can tell. bottom one is.. frigidaire model # fdb1050rec2. please help! thank you
If your dishwasher does not fill up with the correct amount of water the top spray arm will not get the water pressure it should.
The water level should be just under the heating element.
Aug 03, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
Even though I turned up the thermostat on my hot water heater, the water in the dishwasher does not seem to be hot enough. Mold is growing in the food grinder and even though I choose the heat dry option,...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Our glasses don't rinse clean. This is a Frigidaire FDB750RCS0
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
gkj
Aug 15, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher is not cleaning dishes.
you need to check to see what the temps of you water going into the unit is. it needs to be atleast 120 degrees. if not your unit may be waiting to heat the water, until it does then it wont go into the next cycle. it could be the heat cycle is not working so that would cause the unit to not advance.
let the unit run thru the place you think its stopping, but not more then 2 hours. if its not advancing then you might have a bad heating element.
Jan 06, 2009 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire fdb949gf dishwasher won't spray water from arms
Dec 22, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire 24" fdb641rj dishwasher
the check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Feb 07, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire FDB956RB Built-in Dishwasher Logo
52 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
