When i gave the command in zebra after ./configure make it shows the errors I. -I. -I.. -I.. -I.. -I../lib -g -O2 -Wall -c `test -f 'rtadv.c' || echo './'`rtadv.c rtadv.c: In function ?rtadv_recv_packet?: rtadv.c:123: error: dereferencing pointer to incomplete type rtadv.c:124: error: dereferencing pointer to incomplete type rtadv.c:124: error: dereferencing pointer to incomplete type rtadv.c: In function ?rtadv_send_packet?: rtadv.c:149: error: invalid application of ?sizeof? to incomplete type ?struct in6_pktinfo? rtadv.c:194: warning: operation on ?node? may be undefined rtadv.c:268: error: dereferencing pointer to incomplete type rtadv.c:269: error: dereferencing pointer to incomplete type rtadv.c: In function ?rtadv_prefix_lookup?: rtadv.c:476: warning: operation on ?node? may be undefined rtadv.c: In function ?rtadv_config_write?: rtadv.c:977: warning: operation on ?node? may be undefined rtadv.c:982: warning: pointer targets in passing argument 3 of ?inet_ntop? differ in signedness make[2]: *** [rtadv.o] Error 1 make[2]: Leaving directory `/home/valli/Desktop/zebra-0.95a/zebra' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/valli/Desktop/zebra-0.95a' make: *** [all] Error 2
Any solution to this problem?
Best regards,
David.
Posted on Sep 30, 2011
How to configure qubee wimax usb modem in Ubuntu 10.10
Hi. This is alot of info, but here goes.
1. Make your ubuntu up-to-date and install necessary packages.
Code:
# update & upgrade ubuntu
sudo aptitude update
sudo aptitude full-upgrade
# dependencies
sudo aptitude install build-essential ia32-libs linux-headers libnl-dev
# library libnl 32bit version manual installation
wget http://mirrors.kernel.org/ubuntu/poo...1.1-5_i386.deb
ar vx libnl1_1.1-5_i386.deb
tar -xzvf data.tar.gz
sudo cp ./usr/lib/libnl.so.1.1 /usr/lib32/
sudo ln -s libnl.so.1.1 /usr/lib32/libnl.so.1
ldconfig
2. Download WiMAX Network Service 1.4.0 from http://linuxwimax.org/Download
3. Extract files from archive
Code:
tar xjf WiMAX-Network-Service-1.4.0.tar.bz2
cd WiMAX-Network-Service-1.4.0/
4. Build & Install
Code:
# configure
CFLAGS=-m32 ./configure --sysconfdir=/etc --localstatedir=/var --mandir=/usr/share/man prefix=/usr/local --with-i2400m=/usr/src/linux-headers-`uname -r` --build=i386
# do kung fu :)
for i in `rgrep CFLAGS\ = . ' grep -i makefile ' grep O2 ' sed -r "s/([^:]*):.*/\1/g"`; do sed -i "s/CFLAGS = -O2/CFLAGS = -O2 -m32/g" $i; done
# build
make all
# install
sudo make install
boy i hate this post when it changes things to what it thinks it should be,
try this one sir
sudo cd ./usr/lib/libnl.so.1.1 /usr/lib32/
cd is for change directory
thanks for not getting upset during this, and good luck.
I truly hope that I covered everything in it, I think I did though.
Feb 13, 2011 | Computers & Internet
Command error on Zebra p330i
some commands don't work on some printers, depend the firmware and the printer P110 or p330, what commands you sending?
Sep 03, 2010 | Zebra P330i Thermal Card Printer
Zebra TLP 2844-Z appears to print from the iSeries/AS400 but nothing prints no error message Set up same as other Zebra printers that are working printing bar codes
check the connection configuration (if is com port, check speed, flow control and others)
Try to install locally with segull drivers (www.seagullscientific.com) if you need, reset to factory defult. print a test label from the driver. if is comunicate, is not printer problem, is connection problem with your software.
Aug 17, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Manual command settings in zebra 3301
need to be more especify ?!?
to send commands to the printer, go to the driver.
to calibrate send !SA command.
To print card test send IM command.
to reset senr R command.
hope help you.
Aug 16, 2010 | Zebra P330i Thermal Card Printer
On Zebra 105Se printers, what is the a command line to allow label length calibration (2-3 labels used), but not sensor sensitivity adjustment (which wastes so many more labels). I know it exists, as...
The line is part of the ZPL (Zebra programing Language) set and can be downloaded at http://www.lancerlabels.co.uk/zplcommands.pdf
The command you want is on page 187.
Jan 14, 2010 | Zebra 105SL Thermal Label Printer
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra 4MPlus printer erroring
check the driver setting USE PRINTER CONFIGURATION
Mar 17, 2009 | Zebra Z4Mplus Label Printer
ZEBRA Z140 PRINTER sw error ADDR:0080F298
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Mar 13, 2009 | Zebra Printer 140-751-00000
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
