Question about GE JES1851 Microwave Oven
Microwave jvm1860 my microwave jvm1860 does not heat inside
I had a repair man out to fix my microwave and all it took was to reset the unit. We shut off the power source ( at the breaker box ) and turned it back on. This had the effect of a reset. Now it works fine. Hope this helps.
Posted on Jan 09, 2007
Light comes on motor runs,does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 03, 2011 | GE JVM1860 Microwave Oven
Doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Oct 27, 2010 | GE JVM1860 Microwave Oven
All functions appear to be working, but food is not heating at all - worked yesterday, but nothing today.
Basic Microwave Oven TroubleshootingTips
heatman101,/.l;l,.
Apr 24, 2010 | GE JVM1860 Microwave Oven
GE MICROWAVE JVM1860 STOPPED HEATING
-door inter-lock switch(s) / monitor switch
-thermal cutout
-door, triac or circuit board fault
all of these could be culprit
all of these can be tested let me know if you need further instructions.
Oct 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
My jvm1860sd001 model is not heating up
Check the following before you replace the Magnetron device.
1. Check the diode located inside the unit on the noise filter board assembly. it may be damaged.
2. Check the Magnetron Cut-Off Fuse. this will shut off the heating device if there is a fan issue.
3. Check the H.V. Capacitor for burn marks and, discolored terminal points. this will be a sign of a malfunctioning Capacitor device. replace if needed.
If all is ok with the above check list, replace the Magnetron tube.
Jul 09, 2009 | GE JVM1860 Microwave Oven
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
Ge jvm1860 microwave oven
Could the noise you are hearing be maybe an electical sparking/arcing noise? It could be that the wave guide cover inside the micromave cavity is dirty, and needs to be cleaned. If it is not, then it could be a bad magnetron crackling and going bad. If this is the case, it is likely going to damage the waveguide and render the microwave unrepairable. I wouldn't use it until you have it checked out or take it apart and check it out yourself. Hope this helps.
Oct 17, 2006 | GE JVM1860 Microwave Oven
GE JES1851 Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
