Question about Tools & Hardware - Others
Adjust blades on Ryobi plainer
I was given a planer with no instructions and the blades were blunt. I resharpened them and now I need to adjust them.assistance is apresiated.
Russell.
  • brookfieldsa Dec 30, 2008
    need to adjust the cutting blades, have no manual
  • 8,197 Answers
Go here and pick your plainer and look at manual on top of pic.
http://www.ryobitools.com/products
Posted on Dec 15, 2008
Plainer won't adjust up and down
Wood chips are probably jamming the height adjustment, and need to be cleaned out. Lubricate the machine once it's clean.
Feb 01, 2014 | Dewalt DW735 13-Inch Two Speed Thickness...
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
I have a 12 5/16'' ryobi planer and need a place to get a set of knives and books.
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
Oct 18, 2009 | Ryobi Thickness Planer Blades
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Seeking spare blades for RYOBI TOWA Hand Planer
Planer blades L-120N available on ebay from User ID:byarose2005
May 16, 2009 | Tools & Hardware - Others
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Tools & Hardware - Others Logo
281 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
