Question about RCA RS2652 Shelf System
Stereo won't read cds
I have this stereo it is an rca rs2653 it doesn't read the cds we put in the slots it has a 5 disc changer but sometimes only reads one cd and now it has decided to not read any. there are cds in it and it is put to cd setting and i have even tried unplugging it and plugging it back in and it works for maybe a few songs then says no disc and does nothing. any help anyone might have would be very appretiated thanks
  • 6 more comments
  • Anonymous Jan 04, 2008
    My RCA RS2654 will read the cd for only about 5 seconds and then stop reading the rest of the cd or song it was on.
  • jrinri Feb 20, 2008
    my system takes in the cd's, reads each, and then the unit will read NO DISC!
  • Anonymous Apr 04, 2008
    Yes, exact same problem -- when I load one, two or all 5 (any number) the display reads, "READ ERROR NO DISC" - the radio and tape features work, but not the CDs - mine is RS2653 - i have no manual
  • Anonymous Oct 13, 2008
    Starts playing okay. But will read that disc a few seconds and then will skip to a later part of that disc or to another disc comp. It is 1 month out of warranty.
  • charliesalsa Dec 15, 2008
    My RCA Audio System doesn't play so just one CD. And When I push The skip button to change the disc number only show me on the display "disc 2' but do not turn to the selected CD. Also Ipush the Open and Close button and the reel doesn't open or close.
  • Anonymous Dec 29, 2008
    my problem is the same. put cds in and will light up as being read, but when you go to play them it says no disc.
  • Anonymous Jan 25, 2009
    I also have the same problem: my stereo says "no disc" when I put a CD in any of the 3 slots of my stereo. I bought one of these cleaning CDs but couldn't play it because it continued to say "no disc" ! I'm afraid the next step is going to take it to a repalir shop...any other suggestions?
  • prittaygirl Apr 06, 2009
    I have the same problem.. My RCA RS3287 will not read ANY CDs at all. No matter the CD type, it tries to read it and then just says no disc. I think we should start boycotting RCA.
RCA rs 3287. Tuner works, tape works but CD's will not work. Cannot get cleaner in because it will not read disc
Posted on Mar 21, 2011
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Posted on Jan 10, 2007
SOURCE:
I a home rca 5 disc cd changer it will read my cds
Hello
Hello
You have an RCA 5 disc CD changer and it reads CDS. Then what is the fault?
Jan 17, 2012 | RCA Audio Players & Recorders
Can I hook up 4 speakers to my RCA system?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RS2653-manual/id/404ci767/t/2/
Do you mean other than the ones that came with it? NOT recommended. But not impossible either. You assume all risk of equipment damage if you proceed.
First, kiss your warranty goodbye.
I'd go with a series connection or you WILL present too low an impedance to the modest amps.
That means + to minus on one speaker, then + of that speaker to - of the next, then + of that speaker back to - on the amp. Repeat for the other channel.
Start with LOW VOLUME and see how the amp reacts. Of course, you'll have no way of controlling individual volumes so if the speakers are mistmatched it won
Feb 26, 2011 | RCA 100-Watt Stereo System With 5-CD...
The stereo turns on fine but when i put a CD in it says no disk, and i have tried cleaning it but that didnt help. any suggestions?
If you have cleaned the Laser assembly and it is not reading the disc, there are few reasons that would be the case, a bad spindle motor "pladder won't turn" stepper motor or worm gear not working "tracks the laser ***" the laser eye has become defective. The bottom line is you need a complete CD assembly to fix the problem and it probably would not be cost effective.
Dec 20, 2010 | RCA 100-Watt Stereo System With 5-CD...
The cd door is stuck as if a cd is out of place. Won't open enough to see the problem.
Before, when trying to see the problem, I clicked "skip" to see if it would go through all the discs. It did, but still wouldn't open the door. Later, I clicked "play" each time, then "skip", and after going through all 5 discs, the door opened. Go figure.
Dec 19, 2009 | RCA 100-Watt Stereo System With 5-CD...
I have a 5 disk cd Changer stereo and it is not working. My cds are not being read...
you should clean your cd"s and cd player firmly and if it doesnt work still its the cd"player and you should return it if you have a warranty or connect it to you your dvd player and play your cd's from there=
Nov 28, 2009 | RCA RS2653 Shelf System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
RCA RS2652 Shelf System Logo
1,796 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
