Question about HP Office Equipment & Supplies
My printer won't print on photo paper. It keeps sending "out of paper" message
    Scholar:
  • 174 Answers
Disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Posted on Nov 26, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
After printing on cardstock paper from Avery, I have attempted to print on the back side of the same paper. The printer will not allow it. Keeps sending me a message saying "out of paper", and there is...
Possible that the paper indetect is sensing a bad signal from the used paper and so is not accepting , it can also be black spots which may not reflect the opto sensors.
If with the right printing paper- new- there is no issues please do not attempt to correct.
Sep 28, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
21 people viewed this question
Ben Johnson
