Question about Dryers
Older whirlpool dryer gets too hot when using automatic setting
This dryer is about 25 years old (model lfe7500n1). It works fine except on the automatic cycle when it gets way too hot regardless of the temperature selection. Using the timed cycle does not seem to have that problem and works fine. Both regular and permanent press cycles malfunction in this manner.
    Genius:
  • Dryers Master
  • 1,198 Answers
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Posted on Nov 27, 2008
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
Whirlpool dryer model LER7646E02 will not turn off
When they wont shut off it is almost always the timer Sorry.
Feb 09, 2013 | Whirlpool Dryers
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Clunking whirlpool drier
rollers and or felts are cheap,
much cheaper than a new dryer,
and nobody now makes a dryer that will last 25 years.
I have maytags 1972, 1974, kenmore 1968, speed queen 1980,
in each apartment building used by 11 families, to keep them running costs peanuts
new dryers?, - 3 years is all you get before the $$$ starts
Oct 04, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
Marvin
Marvin
