Question about Uniden TRU94852 Phone
Answer Machine My machine will not pick up when someone calls even though it is set up for it.. My phone just rings and rings... What to do???
SOURCE: No ring and no answering machine.
My phones work, but the answering machine does not play back. My friends say that the machine on their end leaves a message.
Posted on Jun 16, 2008
  • 3 Answers
SOURCE: I have a uniden phone
Go to: How to set ring delay in your owners manual.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Posted on Oct 23, 2009
  • 2761 Answers
SOURCE: How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
Bill B
Posted on Mar 04, 2010
  • 2069 Answers
SOURCE: I have 2 cordless and
when the handsets show searching, that indicates that they are having difficulty registering with the base. problem here could be the base itself. solution is to turn off base, unplug from wall socket, wait for about an hour, connect base and power it up. you may have to re-register the handsets for them to work again.
Posted on Jan 13, 2011
SOURCE: I have two residences and
its come base. how can remove that
Posted on Mar 21, 2011
0 characters
1 Points
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Phones
Answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
Aug 03, 2008 | Uniden TRU9485 Cordless Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Phones
How to refuse call and have answering machine pickup
dont answer.
your machine should have a setting that will allow you to set the number of rings before the answering machine picks up the phone. Default is often set at 3 or 5 rings.
look throughout your menu system for the setting.
Oct 04, 2009 | Uniden Cordless Phone
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
Exact same problem.
Is this a system phone?
It sounds as though your set is not programmed with a line appearance. and line preference is not set, this can be set for intercom, or a line or nothing when you pick up the phone. You can do a pick up code to answer until an appearance is programmed on your set.
Aug 05, 2009 | Phones
Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
Dec 21, 2008 | Phones
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
MD481 does not ring when incoming calls come thru and answer maching does not pick up.
try going to this link and looking for additional seetings for your phone or troubleshooting instructions-link is for complete user manual for your phone
Dec 20, 2007 | Motorola Mobility MD481 Cordless Phone
Setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
Dec 16, 2007 | GE 28112EE2 Cordless Phone
Uniden TRU94852 Phone Logo
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
