Question about Canon imagePROGRAF W6400 InkJet Printer
Ink filling maintance cartridge
I turned on machine and it started a filling cycle until the maintance cartridge was full. I put in a new maintance cartridge and new ink and the same thing happened. Nearly $500 worth of ink into the waste cartridge
  • gproskop Dec 02, 2008
    Answer did not solve problem!
    Scholar:
  • 174 Answers
Disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Posted on Nov 26, 2008
IPF700 keeps replenishing with ink after power went down
I had the same problem and the answer was relatively simple: the head was not seated perfectly in place.
The left printing head of my IPF 8300 went bad and called for replacement (was popping an error requiring to reboot the printer and was almost 1000 days old), so I got a new head. When the new head was in, the machine entered the that replenishing ink spiral which first filled up the maintenance cartridge and then, after spending $100 to get a new MC, kept replenishing until one of my inks ran out and stopped with en error code. At that point I ordered 7 bottles of inks that were low and entered the service mode to clear the error and see what's going on. I ran nozzle check, and surprise, for the left head I just replaced printed nothing, completely blank! I put the old head back and the machine worked just fine so I called Canon to complain they sent me a bad head for $500 and they said not to worry, I have 1 year to get it replaced for free, but the problem is not the head but me not seating it properly. Too bad I wasted all that ink and a MC. To summarize, if the replenishing process takes more than 5-7 minutes after replacing the printing head, unplug the machine (will be only way to stop it) and restart in service mode (press power while holding down Load and Navigation buttons until the small S gets on the LCD) and print a nozzle check. If comes out blank for the new head, that is where the problem resides. Reseat the head and restart the printer. If problem persists Canon will replace it for free.
Nov 29, 2012 | Canon iPF700 InkJet Printer
Tip
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
on Jan 04, 2010 | Office Equipment & Supplies
Cannon Mp780 not printing yellow at all. Ink tanks are full.
CANON MP780 DOES NOT PRINT
This is what works for me. Try at your own risk. You may need to clean both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The one separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
#8
Jan 01, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Black ink not work.
CLEAN PRINTHEAD:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Unplug the printer. Put the sponge pad back in using your fingers (do not drop it). Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
#12
Dec 27, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Bought new remanufactured cartridges. Unfamiliar with printer. Trying to print a church bulletin and it is only printing color. No black is printing.
CLEAN PRINTHEAD:
#13
Dec 17, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Since changing 3E black cartridge test print is not good. I've done deep cleaning etc
CLEAN PRINTHEAD:
#15
Dec 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Replaced the two black ink cartridges but still not printing clearly in black, ok in color
CLEAN PRINTHEAD:
#18
Nov 29, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Have a canon Pixma 780, all ink tanks full but only prints all colours but not black
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Installing new cartridges and showing empty
Is this a genuine Brother cartridge or a compatible/refilled cartridge? Inside, at the rear of the cartridge there is flag which when full blocks a sensor in the machine indicating the cartridge is full - with some compatible and refilled cartridges the flag may not be set correctly so the sensor sees that there is no ink in the cartridge. As a temporary fix place some black tape over the rear of the cartridge where the sensor arm is.
Sep 09, 2007 | Brother Multi-Function Center MFC-240C...
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
76 people viewed this question
old marine
old marine
