Question about RCA F27242GY 27" TV
Is it digital ready or do i need a box
Iam talking about an antenna hook up
  • 905 Answers
Yes you will need to get a box to watch the new digital signals that will replace the old analog signals that your set picks up now
if you have cable or sat. you can get the digital signal thru them also.
electech
Posted on Nov 26, 2008
Hitachi 50V500A. How do I get free broadcast channels? Do I only need an indoor antenna or a converter box as well? How do I hook them up?! I'm confused!!
If your Hitachi TV is "digital ready", you do not need a converter, just an antenna. Otherwise, you will need to connect the antenna to a converter and connect the converter output to your TV.
Oct 22, 2014 | Televison & Video
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
Oct 27, 2013 | Toshiba 46H84 46" Rear Projection...
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
How do I get an antenna connected to z20lcd1a tv. I don't mean hook up I mean to work from the tv remote The tv is a 20 inch zenith lcd and the antenna is a phillips
If it is a regular coaxial antenna, you don't need to have a specific remote or code other than the controller that came with the TV. If you're talking about a cable box with an antenna, that will be different. You'll need to use a program code from a list on the remote's CBL device key to work the box.
A converter box for digital antenna transmission, on the other hand, needs its own unique remote to work, as far as I can remember.
Jul 24, 2010 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
Is this TV digital ready, or do we need a converter box?
No, it is not a digital ready television. You will need a box if you are planning on using an antenna with it.
If you have it hooked up to cable or a satilite reciever then you don't need a box. It will continue to work like it is now.
Jan 24, 2009 | Orion Televison & Video
Is the f38310 digital ready or do I need a converter?
No you do not need a converter box your television is digital ready. I use mine with a regular antenna and recieve many channels mostly High Definition and some analog you should notice that when your hooked to a quality HD antenna and assuming you are within broadcast distance you will be very surprised at the quality you will no longer have blury or faded pictures they will be crystal clear. This is because digital broadcast is either there or it's not. no inbetween although you can get what is called speckling thats where little dots pop up randomly the best olution to this problem is buy an additional antenna and run both antennas in through a splitter and this should clear that problem up redundancy is the answer
Hope this helps
Nov 10, 2008 | RCA F38310 38" TV
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
RCA F27242GY 27" TV Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
