No color when a Hailo HDSTB-8000 set top box is connected and tun
I have purchased a Hailo HDSTB-8000 set top box, when installed and tuned I have a clear picture but no color, even when I bring up the menu there is no color in the menu. The TV it is connected to is a Sony KV-K29SN21 Trinitron Color TV KiRARA BASSO.
I sent the set top box back to the repaires and they could not find a fault, they loaded the upgade soft wear for it and retuned the set top box. Again I connected it too the TV and tuned it in but still no color.
Can you help me?
Cheers Robert
  • Anonymous Dec 13, 2008
    I have the same problem with a Digital STB. I have a black and no sound.
  • 7 Answers
SOURCE: Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Posted on Mar 19, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Posted on Jul 14, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Posted on Jul 18, 2008
  • 10594 Answers
SOURCE: instructions for sony trinitron color tv kv 14m1u
Its very simple TV and you can post question.
Posted on Jul 30, 2008
  • 252 Answers
SOURCE: Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Posted on Oct 19, 2008
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
I have an audiosonic 1201 54cm tv dvd combo. I cant receive any channels, do I need to purchase a set top box?
Connect the TV to external areal, and do a re-tune to it, and see whether it captures all the programmes on air; so that you can make sure that your TV is OK. If not the tuner to your TV is faulty.
If it capture all the on-air channels, and not with your set-top box, the fault is with the set-top box.
Nov 06, 2014 | Televison & Video
Hi, I hv bought Hathway C7000N model Set Top Box, but dont know how to install this, its not capturing singl automatically, neither my cable operator has knowledge on this. Please help how to tune ON...
i am not getting some channels like colors, mtv, and some only name in displayed but picture is not apearing on the screen in hathway c7000n please send me some tips
Jan 21, 2011 | Televison & Video
I have a MXT Standard definition set top box model num: MSTB202SD. When I try to auto tune it comes up database empty, can you help?
The commonest cause of this problem is tuning the set top box when the aerial lead has become disconnected or is plugged into the wrong socket (should be in the rf in or antenna socket) . As part of the normal tuning process, all previous tuning info is automatically deleted and with the aerial lead disconnected you will then end up with nothing. Make sure the lead is properly connected to the aerial and tune again.
Another possibility is to go into the main tuning menu and select return to factory condition. This will force a main reset deleting all data and you will then have to work through the whole tuning process from scratch including, setting your State, setting the tv resolution (720p, 1080i etc.) If neither of these options work, and you are certain that the box is connected to a good signal, then the box may be faulty. Good luck.
Jan 02, 2011 | Televison & Video
Rca big sreen went black and white menue is still in color
Try using one of the other video input options, like AV inputs. If still have black and white picture, then the color processor is having issues. If now in color, then your tuner has issues detecting the chroma / luminance signal.
If you are using an external digital box, this may be the source of the problem as well. If you still have a VCR, connect the coax from VCR to the coax input on the TV, and play a tape. Tune the tv to channel 3 or 4. If in color, then your set top digital box is faulty.
Jun 25, 2010 | RCA Televison & Video
We have a bush set top box with no instruction book. one channell Win (9)is indicating ''no reception'' We were told by a local TV repairer to re tune our tv. How?
You should not have to re-tune your tv as the set top box will be plugged in via a scart lead so its the set top box that needs to be retuned.
Go to the menu of the set box and select new installation under features or set up.
Hope this helps
Apr 09, 2010 | Televison & Video
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
Tunning in all digital stations
Don't know if this was the problem, but I was trying to go through the tuner for the saterllite stations. I tried going through the VCR/DVD unit and now all the channels are tuned. Only problem now is how do I tape a channel through the VCR? I can't seem to tune in the VCR.
Oct 03, 2009 | Televison & Video
Unable to Tune TV to Sky + RF output
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Jan 30, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Jan 08, 2008 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
