Question about Cameras
Fuji finepix f47fd camera error message: ! frame no.full
Go to menu-
find 'frame no.'
- switch from continuous > renew
(resets numbering of frames)
Posted on Nov 27, 2008
Zoom rerror
Unfortunately, many cameras that fall prey to lens error problems ("zoom errors" on Fuji's) can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jul 03, 2011 | Fuji FinePix F47fd Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Camera stuck open and wont switch on
The lens is jammed. There is an internal plastic ring with lugs/clips on it that is easily damaged and jams the lens.
Lens needs to be stripped down, repaired and reset
Oct 15, 2009 | Fuji FinePix F47fd Digital Camera
Zoom out and camera dropped.. now stuck out.. fujifilm finepix f47fd
The guide pins and/or plastic tabs inside your lens damage easily when dropped from even a short height.
lens needs to be stripped down, inspected for damage and reset after any repair.
My email is listed on my tips page on my profile if you require more help
Aug 10, 2009 | Fuji FinePix F47fd Digital Camera
Damaged lcd screen on fuji F47fd
Buy a faulty donor camera off ebay with a good screen. F40fd and F45fd use same screen so gives you more chance of finding one quickly and cheaper (if you get one at a good price) than buying just the screen.
Apr 27, 2009 | Fuji FinePix F47fd Digital Camera
Fuji finepix a900 Frame number full error
Hi!
In case you haven't sorted this out yet.
To fix this go into Menu ---> Setup. From there there's a Frame Number setting. It is normally set to: Continuous. The other option is: Renew which evidently simply resets the picture count. After selecting Renew the error message disappears and the camera works perfectly again.
Great little camera!
M
Mar 17, 2009 | Fuji FinePix J10 Digital Camera
Zoom error at FUJIFILM F47FD
It seems your lens is stuck probably here is some contamination in the gearbox of the lensunit. You can't fix this. The zoom must be replaced.
For UK call Fujifilm
Feb 22, 2009 | Fuji FinePix F47fd Digital Camera
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Cameras Logo
155 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
