Question about Tomtom ONE 3RD EDITION GPS Receiver
Hi, i bought a tomtom 1 3rd adition from a friend. I didnt have the instruction or box just the actual tomtom and car charger. Every time i press home their address still comes up how do i change this. many thanks
  • 3 Answers
On TomTom Go at least: Change preferences/change Home location/ Then select from several options. If you are at your home location then fastest is to select "my location", next easiest is to select "Address", then "Street and number"
Cheers,
Pat
Posted on May 30, 2009
    Problem Solver:
  • 8 Answers
Start at beginning and reset factory settings and it will give you and choice for new home address.
Posted on Nov 28, 2008
Model IR2520 copier. How can I correct error E000000?
Hi you need to clear the error from service mode.
press aditional function
press 2
press 8
press aditional function.
there should be in screen #sssw with arrow ? search for CLEAR press ok one time . then with arrow search for ENGINE press ok one time . with arrow search for ERR press ok one more time . turn the machine off and unplugg it from current for about 5 seconds. turn power on and problem should be corrected. if problem persist replace the fixing heater unit
Feb 19, 2016 | Canon Office Equipment & Supplies
What is error code E000003-0002 on cannon irc 3380i
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Apr 21, 2015 | Cannon Office Equipment & Supplies
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
I plugged the system in, the screen would not come on
Hi.
First check the charger connection. If an alternative charger is available test different chargers.
If the Tomtom is starting, then try first resetting your TomTom.
To reset the TomTom follow the instructions on TomTom website, clicking here: TomTom, portable GPS car navigation systems - Factory reset .
If the Nav is still freezing or is dead after reset, then there is an internal fault.
In both situations the alternatives are going to a TomTom shop or calling the TomTom service number listed on manual and following the instructions given by their representatives.
If the unit is completely dead, as a first thing better going to a TomTom shop and asking to test a different charger.
The charger can also be tested at home using a multimeter on charger connector.
Regards.
Jan 03, 2010 | Tomtom ONE GPS Receiver
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Nov 09, 2009 | Tomtom One XL GPS Receiver
Reset mt 920
Hi..
First of all, do a FULL backup with win explorer or similar asap. Oh, did i mention backup? Do it NOW!
Done? Sure...? Great, then you can carry on.... :-)
- It seems you want to do a reset ?:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
- You can also do a hard reset, but don't see why you should need to, but anyway, here's how to:
  1. Hold reset button pressed for approx 15 sec
  2. Press power button while pressing reset button
  3. Release reset button while still pressing power button
  4. Device should start, hold power button pressed until you see white text on screen, last line should read "RTC..."
  5. Release power button
Hope this helps you to achive you goals...
Apr 22, 2008 | Tomtom GO 920 GPS Receiver
Car accessory outlet
you might be able to go to a local car parts place and have a nice guy check it put for you
Jan 24, 2008 | Tomtom ONE GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE 3RD EDITION GPS Receiver Logo
269 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
