Question about Kyocera FS-C5030N Led Printer
Printer will only print page 1 of multiple page documents
We have a Kyocera FS-C503CN KX that will only print page 1 of multiple page documents. Other computers can use this printer and have no problem printing multiple pages.
  • 1 more comment
  • Anonymous Dec 08, 2008
    i have this same pronlem
  • Jerry Stanford Dec 12, 2012
    I have the 1020D laser which stopped printing more than 1 copy of a page two weeks. Latest driver installed; Kyocera help say it must be a windows update that has caused it.Anyone else getting this problem?
  • Anonymous Mar 18, 2014
    When printing a large black smudge is left on the document. How do I correct this?
  • 40 Answers
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Posted on Jan 12, 2009
When printing multiple pages last few pages come out garbled
You may need to increase the amount of ram in your printer. Or turn it off then on, then try printing the large document. Do this before every print job, if it fixes your error, then you need more ram.
Mar 01, 2011 | Kyocera Mita FS 1010 Laser Printer
We have an Kyocera FS-1118MFP KX and it is printing out everything in really small type. How can I fix this problem?
1. On the computer:
- go on Print Preview, if document looks normal go to step 2.
- make sure you are writing in a font of at least size 10
- make sure you don't have ticked "Shrink to fit", but adjust to 100%.
- size of the paper is printing preferences is set up to A4 or Letter, depending on your region
- there is a known issue with Outlook printing in small font, you need a hotfix for that
2. On the printer:
- You have to go into the menu of the printer and see if there is an option for the font, if there is increase the size of it
- In the menu, make sure the paper size is correct
- None of these worked, you may want to reinstall the drivers of the printer
- If that does not work, you may have to put a new firmware on the printer. You can download drivers and firmware from Kyocera website
Nov 30, 2010 | Kyocera FS-1118 Printer
KYOCERA FS C5030N PRINTS ONLY THE FIRST PAGE OF A PDF DOCUMENT. IT SPOOLS THE # OF PAGES IN THE DOCUMENT BUT ONLY PRINTS THE FIRST PAGE.
make sure you are using the KX PRINTER DRIVER first
if so..
tray changing the pdl format
in the printers and faxes area right click on your printer
right click go to properties.
click on device settings tab (you have this if you are using the KX driver)llhopefully you are
you will see a button (pdl) click on pdl
changed pdl to pcl5e
good luck
Feb 10, 2010 | Kyocera FS-1030DN Printers
USER/INSTALLATION GUIDE/user instructions
1. Go to the following link: http://www.kyoceramita.be/index/service/dlc.false.driver.FS1016MFP._.EN.html
2. In the section "Advanced Search", select "Print" for "Product Category" & "FS-1900" for "Product".
3. Click the "Go" button.
4. Select the "Documentation" tab.
5. Download any document for your printer from this page.
May 22, 2009 | Kyocera Mita FS 1900 Laser Printer
My Kyocera FS-3830N isn't printing certain letters
Updating the driver will solve your problem. Go the Kyocera web page and look under legacy printers in the download area
Jan 21, 2009 | Kyocera FS-3830N Laser Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
Printing Issue
sounds like it got hit by lightning and needs some serious repair... consult a service technician... in your area
Jun 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS-C5030N Led Printer Logo
1,552 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
