Question about Dell Inspiron 1501 Notebook
"Disc read error" Dell Inspiron 1501
I'm getting "disc read error" upon boot up and even after pressing crtl+alt+del the error message keeps popping up on a black screen. Is there a fix for this to get operating system disc to reload?
  • Anonymous Apr 13, 2009
    disk read errorr
    President:
  • Dell Master
  • 1,314 Answers
This means your hard drive is bad. You need to replace the hard drive and then the operating system.
Thanks and please take a moment to rate as fixya.
Posted on Nov 26, 2008
  • 4 Answers
Listen, This doesn't always mean the Hard drive is bad. I have a dell inspiron 6000 and I have gotten that error. It's funny, I can always read the drive using an adapter from IDE to USB and also when I put it in my 2.5" enclosure. In fact, I had a 40G drive which I replaced with a 160G WD(Western Digital).and I later got a read error. So I formatted the old 40 and put it back in and used the 160G as an external drive. Never did get around to backing it up and wiping it. Then one day the 40G died and I just decided to get a 250G WD and it has been working fine until today when I got that familiar read error message. Now I'm pretty pissed so I'm trying to figure it out. I'll try to wipe it and see if that fixes it, but before I do that I really want to find out why and maybe find a better way to fix it for good or discover that it was something that I'm doing. What ever the result, I'll post my results here.
Posted on Dec 31, 2008
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
I want to restore my laptop dell 1501 inspiron it has vista home basic back to factory setting i have tried the f8 and the ctrl +f11 and they dont work can you help i dont have a restore disc
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Jan 08, 2011 | Dell Inspiron 1501 Notebook
Dell mini inspiron 910. On boot " a disk read error occurred press CTRL+ALT+DEL to restart " when I do that the same message appears please help me.
I think you have a hard disk error.
Use your recovery disk, or better still Windows Installation disc, and start the boot up using the menu to select "repair system". That will save you the trouble of having to reinstall all of your software and settings.
If it won't work, a format of drive C will fix your errors but you will have to restore all of your dadt.
Hope this helps.
Oct 25, 2010 | HP Mini 1000 Netbook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Jan 27, 2009 | Dell Inspiron 1501 Notebook
I hav eDell Inspiron 1501 and upon boot I'm getting "disc read error" So Ipress ctrl+alt+del as screen asks, then itreboots againand again saying same thing. Please advise
Hi there robandviv,
IMHO
Unplug the cable that connects your hard disk drive to the motherboard and plug it again. Make sure that the cable is plugged properly. HTH
Nov 26, 2008 | Computers & Internet
Start up problem
hi steve,
can you get into the BIOS?
if so, would u make sure the boot orders are following:
1st. boot from hard drive,
2nd, cd rom
3rd, floppy,
4th, network adaptor?
save changes and try restart.
i hope you do have OS installed.
if not change 2nd part to 1st, and 1st to 2nd.
i have gotten the same error with my laptop. my computer was trying to load window from network, through network adapter.
hope this information helps.
Dec 21, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Dell Inspiron 1501 Notebook Logo
632 people viewed this question
Alun Cox
