Question about Mitsubishi Televison & Video
Light for lamp came on and it stopped turning on...
I replaced the light...nothing changed.
  • 3 more comments
  • dragovon Nov 26, 2008
    My set is Mitsubishi 73827. The light came on for the lamp...and the TV stopped coming on...so I replaced the lamp...hit the reset...and still the TV doesn't come on and the light for the lamp is still on.
  • dragovon Nov 27, 2008
    3 2
    the lamp door cover...that's the exterior plastic door with 2 screws?
    Thanks much...it works now...kudos!!!
  • Sonny Berry
    Sonny Berry May 11, 2010
    If you will post the model number of your set I will most likely be able to help you. Please respond to this same post when responding.
    Thanks
  • Mitsubishi Master
  • 8,617 Answers
Hold the menu and the input/devic buttons both in together on the front of the set for 6 seconds, then and see if it blinks a two digit error code. It should blink a series of blinks pause briefly then blink another series of blinks for the second digit. Let me know the number of blinks.
Posted on Nov 27, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Nov 27, 2008
    32 code is the error indicating that the lamp door cover is open. Double check that the lamp door is secure try opening it again and resetting it. If the code 32 still exists its most likely the lamp door switch that is malfunctioning.
  • Sonny Berry
    Yes, there is a switch that the door contacts when its fully closed so the lamp will not light if the switch isnt depressed
  • Sonny Berry
    Glad I could help.
I have a 2007 yukon denali xl, I got my front brakes and right wheel hub changed. When he got doney brake lights in the back of the truck wI'll not shut off. Brake light switch did nothing to help..
Who put the front brakes an wheel hub bearing on the vehicle ? A qualified repair shop ? A friend ? The front brakes an wheel hub would have nothing to do with the brake lights . An the brake light switch is an input to the BCM - body control module .
Stop Lamps
When the driver presses the brake pedal, the switch contacts open and battery positive voltage is interrupted to the BCM. The BCM then supplies voltage to both the turn/stop lamp supply voltage circuit and trailer rear turn/stop lamp supply voltage circuits. The BCM also supplies voltage to the CHMSL though a dedicated circuit.
I suggest you take it back to who did the front brakes , or a quailfied repair shop .
DTC B3445 00: Stop Lamp Circuit - DO you know what a DTC is ? diagnostic trouble code !
Diagnostic Fault Information
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Stop Lamp Supply Voltage
B3445 00
Stop Lamps Inoperative
Stop Lamps Always On
Circuit/System Testing
Disconnect the stop lamps and test the individual stop lamp assemblies for internal shorts between all terminals.
? If a short between terminals is found, replace the stop lamp socket or circuit board as applicable.
Test the stop lamp supply voltage circuit for a short to ground.
? If all circuits/connections test normal, replace the BCM.
Nov 09, 2016 | 2007 GMC Yukon XL Denali
Brake lights went out so I changed a blown fuse,now the brake lights wont shut off,so I replaced the brake switch at the pedal and still have the same issue,lights wont go off.
Which fuse did you replace ? The one in the under hood fuse box or one of the two in the I/P fuse box . Do the CHMSL - center high mount stop lamps work correctly ? Here is a description how they work .
Stop Lamps
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Does yours have trailer light hook up ? If so check trailer wiring connector for corrosion . Also check the turn signal / hazard module .
Does
Aug 23, 2015 | 2003 Cadillac Escalade
How to change brake light bulb on a 2014 fiat 500L
https://www.fiatusa.com/download/pdf/manuals/2014-FIAT-500L-OM-1st.pdf
it's in your owners manual page 358 chapter 7
you need a torx 20 screwdriver or bit
Rear Tail, Stop, Backup And Turn Signal Lamps
1. Open the liftgate.
2. Remove the two screws and remove the tail lamp assembly.
3. Remove the four screws (using a T20 driver) and separate the backplate from the lamp housing.
4. Remove the tail, stop, or turn signal bulbs by pushing them slightly and turning counter-clockwise.
5. Remove the backup lamp bulb by pulling straight out.
6. Replace lamps as required and reinstall lamp.
Center High-Mounted Stop Lamp (CHMSL)
This light is an LED assembly. See your authorized stealership
Mar 30, 2015 | Fiat Cars & Trucks
03 Chevy Trailblazer left rear taillight will not work. Brake light, back up light & turn signal all work. Right rear all work. Replaced bulbs, switched sides, still nothing.
There was a recall on this, see your local Chevrolet dealer.... Recall Date: NOV 01, 2004 Model Affected: 2003 Chevrolet Trailblazer Summary: ON CERTAIN SPORT UTILITY VEHICLES, VIBRATION AND HEAT MAY CAUSE THE TAIL LAMP/STOP LAMP BULB TO LOOSEN IN ITS SOCKET. IF THIS OCCURS, THE BULB MAY FLICKER AND EVENTUALLY BECOME INOPERATIVE. Consequences: AN INOPERATIVE BRAKE LAMP WILL NOT CONVEY THE DRIVER'S INTENTION OF STOPPING TO DRIVERS IN FOLLOWING VEHICLES, AND AN INOPERATIVE REAR TURN SIGNAL LAMP WILL NOT CONVEY THE DRIVER'S INTENTION TO TURN TO DRIVERS IN FOLLOWING VEHICLES. BOTH OF THESE FAILURES CAN INCREASE THE RISK OF A CRASH. Remedy: DEALERS WILL INSPECT THE TAIL LAMP/STOP LAMP ASSEMBLIES, AND IF NECESSARY, REPLACE THEM. THE RECALL BEGAN ON NOVEMBER 22, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, OLDSMOBILE AT 1-800-630-6537, BUICK AT 1-866-608-8080, OR GMC AT 1-866-996-9463. Potential Units Affected: 871473 Notes: GENERAL MOTORS CORP. Read more: http://www.motortrend.com/cars/2003/chevrolet/trailblazer/recalls/#ixzz2jWJ1eDyR
Nov 02, 2013 | Cars & Trucks
I have a 2003 2 door explorer sport, just recently my turning signal and break light have stopped working on the passenger side!! I changed the light bulb, and nothing!! I changed the turning signal light...
No, because the left side is still working. The loose wiring was to the multifunction switch (turn signal).
Power gores through the turn signal switch to the brake switch on the brake pedal, then to the rear lights. Does the highmount brake lamp work?
At the RH lamp socket, Measure the voltage between the RH rear lamp C4032 pin 3, circuit 5 (OG/LB), harness side and ground. Should be 12 volts.
try that first.
Did you change the front and rear bulbs?
May 21, 2011 | Ford Explorer Sport Cars & Trucks
Just turned projector on - lights are flashing and nothing is working... can it be reset??
which lights? could be the lamp has expired, the colorwheel stopped spinning, the ballast/power supply had burned out, or the fans have stopped. if it's the lamp light, replace the lamp.
Nov 01, 2009 | Optoma MovieTime Digital DVD Multimedia...
I have a Sony Grand Wega KDF-E50A10 50". Turned on the TV and all 3 indicator lights came on RED. There was no sound and nothing was on. Killed the power to the tv , waited 5 mins, rejuiced and it turned...
3 blinks red light is a lamp error, either the lamp switch is dirty or lamp is going, if it does it again reseat the lamp and see if it stops.
plan on replacing the lamp every 2 years or so anyway
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Replaced lamp and new wires, then changed back to old wires still nothing.
Once you replaced the lamp did you reset the hours under the menu? If you do not do that some times the set believes it's in warning mode and prevents a potential implosion of the lamp which creates issues such as the set not turning on, staying on that long, or the lamp light still flashes.
Let me know how that works out for you.
Also, what "old wires" are you referring to?
Oct 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
