Question about Riccar R100 Vacuum
Help my riccar 100 was clogged full of new carpet so I cleaned it out and it wont turn on.
    Problem Solver:
  • 15 Answers
There is a reset button located in back near left wheel, it is white. Use a safty pen or something to push it in and don't forget to remove the clog that caused the problem in the first place before reset. This is a over heating safty. Good, well made machine
Posted on Sep 30, 2013
  • 76 Answers
The motor probably overheated. take it to a vacuum cleaner dealer and see if they can fix it.
Posted on Jul 30, 2009
  • Gammon Master Sep 30, 2013
    It has a reset on it to protect it from over heating. It is a small white button in the back near the left wheel. Use a safy pen or something to push it in to reset and you should be good. Remove what caused the problem first of course.
Contempo. Where is reset button on rear?
Reset button is at bottom on the rear of vacuum.
Oct 20, 2015 | Riccar Vacuums
My Riccar 8850 is very hard to push, even moreso on heavier pile carpet. Know any reason why? Also see my "more details" section.
adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
Oct 07, 2015 | Riccar 8850 Vacuum
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Riccar 8625 doesn't seem to beat carpet but the brush is turning
Your 8625 is well over 20 years old. If it's been over a year since you've replaced the belt start with a new belt. Belts lose elasticity and should be replaced at least once or twice per year. The brush roll will still spin and appear to be working fine but when you put the brush roll onto the carpet it will stop spinning fast enough to clean the carpets.
Jan 25, 2014 | Riccar 8650/8625 s Vacuum
Full bag light is on with a new bag
There is a clog somewhere in one of your tubes and/or the filters need replaced
Jan 04, 2014 | Riccar Vacuums
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
May 22, 2010 | Riccar 8850 Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
My riccar will not work
Reset button is located in rear near left wheel. A white button, push in with paper clip to reset
Dec 13, 2009 | Riccar R100 Vacuum
No suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
Feb 25, 2009 | Riccar 8850 Vacuum
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
125 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
