Question about Tools & Hardware - Others
Screw gun not working
Screwdriver bit misses the screwhead in the screw strip
  • 2,176 Answers
You might try and login to Makitatools.com website and look at an owners manual for hints on how to adjust this tool. Make sure that you have the model number to type into the site search engine.
Or give me the model and I will see what I can come up with.
Dave
Posted on Dec 26, 2008
Drilling out screwheads, not screwing the screw in!
Sears has a great easyout bit setup. They work great for getting stripped screws out.
Jun 01, 2017 | Drills
I cannot remove screws from wood the drill just just turns on the phillips screw head
The screw is either broken ,the hole stripped out, or screw not into something solid.Try prying up under the screwhead with something as you turn it with the drill
Apr 19, 2011 | Dewalt DC720KA 12 18V Cordless DrillDriver...
On car keys cant get screws out to replace battery
Try getting a 'jewelers' set of screwdrivers, or screwdrivers that are used for watches and eyeglasses. They're not expensive.
If the screwheads are damaged, then you might try to drill them out with a small bit.
Unfortunately a lot of modern key fobs are made this way.
Jul 04, 2010 | 2006 Honda Pilot
Ferroli optimax he 31c diverter valve noisy, does anyone have details of how to remove and strip to se if some debris is making it stick slightly and be noisy. Any help would be very much appreciated,...
there is just two screws holding divertor valve in remove these screws (do not touch painted screwheads) then twist left to right and pry gently were the two screws were fitted. best bet is to replace diverter valve head to stop noise
Mar 04, 2010 | Quasar HQ2051TH Air Conditioner
The bit in my Stanley ratchet screwdriver does not lock into place, falls out when screwdriver is pointing down
There is a small springs steel wire that fits into the chuck. the bit slides into the chuck and then into the spring and the spring holds the bit inside the chuck. This ring seems to be missing. Thus the bit falls out. You might try going to a hardware store and they make a device that is two magnets held together with a rubber band. When they are together there is a small hole in the center. You can slide any screwdriver or bit into the hole in the center and it magnetizes the bit or driver. Magnetizing your bits should keep them from falling out of the ratchet screwdriver.
Dec 04, 2009 | Tools & Hardware - Others
IMac G5 CASE SCREWS STRIPPED
just replace the screws with a slightly larger thread
this will give you an idea of what is available (which you should be able to purchase at any hardware store)
http://www.accuratescrew.com/Captive-Screws.aspx
Robert
Jan 29, 2009 | Apple iMac G5 Desktop
Disc Brake replacement
You need an impact screwdriver. You should be able to pick up a cheap one from your local parts store. You hit the impact screwdriver with a hammer and it forces the screwdriver bit to turn. But make sure you are using the correct size bit, or youll strip the screws and itll be a pain to get them out.
Dec 25, 2008 | 2006 Honda Pilot
Conection of a beko electric cooker
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Nov 26, 2008 | Ovens
Tools & Hardware - Others Logo
55 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
