Akai lcd tv has no picture
The green power light comes on at the bottom of the tv but there is no opening screen or any picture at all
  • 3 more comments
  • Anonymous Jan 01, 2009
    power but no picture
  • mario07 Jan 11, 2009
    Power adapter failed
  • Anonymous Feb 04, 2009
    power light on, screen lights up, nothing on the screen. firmware update via usb fails, since nothing appears on the screen.
  • Anonymous Apr 27, 2009
    green light goes on but no picture
  • admin761 May 01, 2009
    Short flash of channel name when the screen goes black. Tried to unplug it but nothing helps.
retrohack
  • 27 Answers
SOURCE: akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Posted on Oct 23, 2007
  • 13 Answers
SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted.  Most likely through the service menu, if units under warranty you can call Akai.  For further structures.
Posted on Oct 24, 2007
  • 4 Answers
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
praky16
  • 744 Answers
SOURCE: AKAI LCD TV - power light stays red, won't turn green
hiii.....
If the power supply is supplying the main board with the correct amount of volts, your controller board or your on off switch panel is malfunctioning and needs to be replaced. If its the whole board your looking at a few hundred unless you can find the same tv with a broken screen and just swap parts.The on/off switch board is cheaper but you have to remove alot of interior parts to access and becomes a hastle.
thank u rate me!!!
Posted on Feb 12, 2009
  • 8 Answers
SOURCE: Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Posted on Sep 08, 2009
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Akai lcd 2oinch tv
Your power supply is bad. This model came with a bad design. Your supply may have a green light on the black box, but it is putting out low voltage or amps. Replace it and you should be good to go.
Sep 27, 2008 | Akai LCT2070 20 in. EDTV-Ready LCD...
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Initial power-up
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Dec 17, 2006 | Akai LCT2060 Television
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
